Car moving fwd while in drive with brakes on ?
I noticed while I'm say in a drive thru , in gear with the brakes applied every 30 seconds or so the car will jump forward on it's own... As if I let off the brakes for a second or something , kinda weird , can't remember if it's always did this or not .
Is that normal ?
Is that normal ?
shifting at 7k
do you have a surging idle when that happens? check your rpm guage. i remember my car was doing something similar it was just moving on it's own at abnormally above idle rpm's on a few occasions during heavy stop and go traffic. turned out to be a vacuum leak, but i have a 6 speed so i dunno if i can compare.
I don't think it's anything to be checked , car runs fantastic
lowrd on tein CS biatch
does the car overpower u braking hard?? or just overpowers u if u are on the brake just enough to regularily stop the car? cause when the car goes to turn on the a/c or rad fan(s) the idle will get stronger to compensate for the added load on the alternator..
this causes the car to become harder to stop as the idle is now stronger
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
