car idling rough??...
Old Sep 28, 2004 | 06:54 PM
PiMpiN wHITe Cl-S's Avatar
well just recently my car started to idle at little werid. its hard to describe..but when my car is at a stop and i let go of the brake a little the car just shakes a goes away. this happens each time. anyone know what the problem is?
Old Sep 28, 2004 | 07:08 PM
chabanais's Avatar
Oxygen sensor?
Old Sep 28, 2004 | 09:32 PM
babyblue's Avatar
Sold but not Forgotten...
Did you try fuel injector cleaner? I had that happen to me six months ago... Used fuel injector which solved it...
Old Sep 28, 2004 | 09:58 PM
Titand19's Avatar
East Coast Boost.!
could be a slight misfire, timing problem.
Old Sep 28, 2004 | 10:33 PM
StypeCL's Avatar
Spark plugs?
Old Sep 28, 2004 | 10:52 PM
NiteQwill's Avatar
Adventurist.
If it was a misfire, your CEL light would throw a code. Adjust your idle screw?
Old Sep 29, 2004 | 12:30 PM
Excelerate's Avatar
Former Sponsor
Try also shooting some Air Intake System Cleaner in the TB. This also might help.
Old Sep 29, 2004 | 04:46 PM
mattdaddyz's Avatar
M to da DZ
Did anyone find a cure for this? My car has recently started doing this. IT's not a violent shake, but I can hear it and feel it. I just recently got the oil jet kit installed but my shifting is just fine, no slips or flares.
Old Sep 29, 2004 | 04:53 PM
VeeralS05's Avatar
I NEED MONEY!
i'm guessing the sparkplugs, but to check if they are fading drive at a abt 60mph speed and barely press the gas down and if the acceleration shakes...and feels like a cutting off and on really fast...it will be the spark plugs...same thing w/ mine, but i jst dont want to change them until my 30K mile service
Old Sep 30, 2004 | 02:55 PM
dgracer's Avatar
I agree with the person that siggested carbon build-up fixed by FI cleaner. Get some Techron (2-3 bottles at Costco for 9.97) and use it for 2-3 tanks in a row. It will smooth it out. I use it at every oil change. You'd be amazed how much carbon sits on the back of the intake valve after only 10k miles.
Old Sep 30, 2004 | 03:21 PM
CLpower's Avatar
teh Senior Instigator
my car use to do this till I replaced the IACV
Old Oct 2, 2004 | 09:32 PM
Tosh's Avatar
Eurotrash
If your idle speed is fluctuating or surging, like mine does intermittently, it's probably a bad or dirty idle air control valve. Seems to be quite a common problem....
Old Oct 3, 2004 | 04:16 AM
Dem1K's Avatar
Got a Job!
I have a SIMILAR problem...but not the same...
Whenever I start my car...after it has been sitting for usually the night, the car idles funny for a minute or two. The RPM's will go from 750...to like 900...down to like 600, back and forth, and the gauge lights fade in and out a little bit as the engine rpm's decrease. It almost sounds like the engine's exhausted after doing a long sprint or some shit? Any ideas?
Old Oct 3, 2004 | 05:14 PM
Tosh's Avatar
Eurotrash
Dem1K, you are describing exactly what mine does (although mine can do it any time it's idling, cold or warm), and I believe I have a dirty IAC valve. But, as I haven't found step by step instructions with photos on how to clean it, I haven't tackled it yet....
Old Oct 3, 2004 | 06:43 PM
Dem1K's Avatar
Got a Job!
isn't it a pain in the ass? I feel like my car is going to die out
Old Oct 3, 2004 | 08:25 PM
LaurenCLS03's Avatar
8th Gear
I agree with the idle air control valve however your ECu would throw a code. Is your check engine light on?
Old Jun 13, 2006 | 11:11 AM
mefromuic's Avatar
I have this exact problem. It doesnt happen all the time but its happening more frequently now. When ever i come to a complete stop whether at a stop light or in park, i get surging. When i pump the gas to try to smooth it out, it surges more and feels like its going to die. The RPM goes as low as like 100. From the AZ searching i've done, it seems like its the IAC valve.
I've know thers a screw that can adjust it, do i turn it clockwise or counterclock wise. Which way gives more air and vice versa? I recently just changed my oil and switch from dino to full synthetic iwth a bottle of Pro-Blend. Maybe somewho that threw the amount of air needed at idle off a bit? I mean i noticed the rough idle before but its more frequent and pronounced after the oil change. Or it has nothing to do with it and it just got worse with time.
Anyways, I found this thread also:
https://acurazine.com/forums/showthr...+control+valve
but i dont want to replace it unless i have to. Where do i look to get one cheaper, most of the usual part sites dont carry this IAC valve. I checked ebay too.
Also, my maintanence required light (not the engine light) flashes on during the heavy surges.
TIA
Old Jul 8, 2006 | 12:02 PM
slingman's Avatar
same issue...
I think I have the same problem. But my engine light is on.... just recently though. The idle issue has been about a couple of months now.
I think I will go replace the IAC valve now.
Old Jul 8, 2006 | 05:45 PM
Type S Zero's Avatar
i just found a new tsb on this exact problem, published on july 6th 06.
it tells to replace the front lower engine mount (50800-S0K-A81) with a new part (50800-S0K-A82)
Old Jul 10, 2006 | 09:31 PM
SILVER-TYPE-S's Avatar
Rookie Season
I briefly had a rough idle right problem right around the time the fuel refineries moved off of MTBE and over to 10% ethanol blending. The ethanol is a stronger solvent and can losen up old petroleum deposits in the fuel system. Mine cleared up by the next fill up. It hasn't happened since. The car's computer may also need time to make adjustments to the new fuel.
Might want to try fuel injector cleaner and replace the fuel filter. Just a suggestion... Seems more likely than an IAC valve epidemic.
Old Jul 10, 2006 | 09:46 PM
quicksilver10101's Avatar
its the oxygen sensor ive had mine go twice and i experieced all the same problems...it gets progressively worse for months before the cel comes on
Old Jul 10, 2006 | 10:48 PM
Sun Diego CL-S's Avatar
says "hello to my TLX".
yep. that IACV is one of those damned faulty parts for our cars.
Old Jul 10, 2006 | 11:53 PM
BigLizard's Avatar
Moderator Alumnus
That sucks, mine does it too =( It started to do it worse after I installed the CAI.
Old Jul 11, 2006 | 09:36 AM
oh man, ditto. i had all that shit disconnected for awhile since i installed both the Icebox and TB spacers at the same time. right after installation, it pulled like a mother. but then after, it started getting a rough idle.
Old Jul 11, 2006 | 07:04 PM
BigLizard's Avatar
Moderator Alumnus
When I saw the list of things that are wrong with the car after I bought it, I was like
Old Aug 15, 2006 | 01:38 AM
SIRSIG's Avatar
THE J35A2...
i have seen this type of problems one to many now, lots of thread regarding "rough idle, etc..." many posted their testimony here, but still without a direct answer i'm getting the same shit too. rough idle, hesitation and cutting off @ 5500RPM (i have 6spd.) i'll go to Autozone tomorrow morning for codes...hope to close this deal once and for all... i'll keep you guys posted.
Old Aug 15, 2006 | 04:39 PM
SIRSIG's Avatar
THE J35A2...
yup, my IACV is shot. replaced it, and the car move again. thanks typeR and Cocoa for the info.
Old Aug 22, 2006 | 04:32 PM
VWNOWHONDA's Avatar
Iac
where is the idle control valve located inside the engine bay
Old Aug 22, 2006 | 04:42 PM
it is attatched directly underneath thr throttle body. it is everything in the box under item #2 in the illustration below.
Old Aug 25, 2006 | 07:58 AM
VWNOWHONDA's Avatar
Idle
Thankyou
Old Aug 25, 2006 | 04:16 PM
grey6spd.'s Avatar
car idling rough
check out post " can you over rev a cls 6spd" for a real horror story. be careful with F. I. cleaner and rpms as you might be looking at a $4000. repair job.
Old Aug 27, 2006 | 06:52 AM
stic2it's Avatar
How much to do the repair?
Old Aug 29, 2006 | 12:44 PM
grey6spd.'s Avatar
repair over revved engine
Bent valve in left head $3200 and some change to install new head ,replace anti freeze @oil. I hope this includes trouble shooting original problem of check engine light. I'm not getting any help from acura because acura of clevelands "expert" mechanic says so even without any codes on the ecm recorded. Acura of cleveland has only been here for about two years so i'm wondering if this "expert" has even worked on a 03 cls before. Hopefully they find the real problem in that price.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
kuzdu
Sep 10, 2015 08:42 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
