can't rev engine past 5250rpm...
whoXwanXsum
sitting in my car waiting for my GF last night i was playing around a bit...
i rev'd the engine just to hear the sweet sound and it wouldnt go past 5250rpm. all it would do is bounce off of 5250rpm. i was in P if that matters at all. when i drive the car it will redline every gear. so why only 5250rpm at a stand still?
im back
its called a rev limiter, so this way when you're sitting in park and you're revving your engine you can't bring it to like 8grand and do some nice damage...and you can hit vtec when the car isn't moving cuz my rev limiter is at 58ish and you can clearly hear the vtec, i also have a 6spd
when i have the clutch in at a stop i know i cant rev past 5 k or so but if i let it roll forward a bit then put the clutch back in and rev it it lets me go all the way up, im not sure about neutral ill try it today
Originally posted by dbox
i figured it was a limiter but i have never heard of this being in any other car. i just wanted to make sure nothing was wrong...
You have the ability to "slew" (change the revs rather quickly), in neutral and park without a "connected" load (1st, 2nd, etc) to limit the change in revs/sec (slew). There is also torque converter -- in the case of the automatic -- hanging on to the crank (it's along for the ride). When the car is in "gear", the torque converter is basically absorbing the energy (engine side moving, tranny side/internals are NOT moving).
"5-Speed Sequential Sportshift Automatic Transmission (back to top)
The TL's transmission offers tremendous weight savings over the previous-generation TL transmission. Almost a third lighter, the Direct Control AT is the most significant factor in the new TL's reduced drivetrain weight. More important to the TL's driver is the new transmission''s refined feel and quick response. With a 16-bit, 20 MHz Electronic Control Unit (ECU) directly controlling transmission operation in concert with the engine management system, linear solenoids provide precise, real-time control of the clutch on/off pressure in the TL's transmission. With superior clutch engagement accuracy, the sophisticated control logic system operates smoothly under all conditions.
Working in concert with this system is a canceler mechanism built into the first and second gear clutches that "cancels" out the detrimental effects of rising fluid pressure caused by centrifugal force–assisting in precise clutch control.
Multiple safety and control strategies use interaction between engine and transmission controllers to manage overall powertrain operation. By limiting engine output torque and/or transmission clutch pressure, sharp driveline shocks are eliminated, and the engine is prevented from exceeding 5000 rpm in Neutral and Park...."
http://www.honda.ca/AcuraEng/Models/...ion=Powertrain
whoXwanXsum
Originally posted by EricL
As described above, this is normal.
rockyboy
12-06-2022 02:29 PM
Mike Bertram
09-10-2015 09:27 AM
