Can't keep cleared lights from fogging!!!!!
what is the deal?i guarantee these babies are sealed.what else can i do?i let them sit over 24 hours in black and decker squeeze vises and they still fog.should i unplug the turn signals for a while to let the air equalize or something(i put this in because i have run out of options,i feel) HELPPPPPPPPPPPPPP
you have a leak somewhere... Mine sealed perfectly for a while, then all of a sudden they started to fog. I found out it was because I didn't use hi-temp silicon so with the heat of the engine and hot AZ summer, they started to separate a little. I'll be redoing them someday.
-Aaron
-Aaron
Mine fogged for like a day after i did my black housings. I took a hair dryer and evaporated all the moisture and put the lights back in on a non humid day. doesnt fog at all now. If you have any moisture in the air after you seal the lights up they will fog Just give them a few days and see what happens. If they still fog reseal them again it only take alittle hole Good luck
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
