cant find tranny filler plug
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
ok, i know were the drain plug is but i am having a real hard time finding the fill plug, were the hell is it in relation to the drain plug, please help!!! im only trying to top it off cause it is low on fluid. also if i was to just drain it would it take more than 3 quarts to top it off?
if you had the tranny recall thing done...they changed out the filler bolt to one with a tube running through the middle of it for oil i think. you need to remove the bracket that holds down that tube in the bolt head. once that tube is out, you'll see the bolt more clearly. its sitting right on top of the tranny if you look right below the air intake pipe. it'll be hard to see since that tube is black and so is the bracket. just remove the bracket bolt and wiggle it out of the bolt head.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
