Can some help with a question?
Not sure, but it will be CLOSE.
Everything is pretty much the same as my setup except for the wheel width.
I’m running 225/40/18 on a 7.5” wide wheel with a +48 offset.
Shawn S
Shawn S
Changin bulbs since '73
Originally posted by CT3.2
sorry to be so direct, but i want to get these rims so i can post picture soon and satify my urge of getting my car looking sweet .
The CL Crazy
So i guess i stumped all the pros out there that thought they new about our cars. Since they can't answer my question.
of if the18x8 offset of 47 will fit.
I think you got some pretty useful info being that your thread has only been up for about 5-hours.
Give it a day or two and see if someone has your EXACT setup.
Like I said originally, your specs are VERY close to mine.
With an 8” wide wheel you should have 1/4” LESS clearance on both the inside & outside of the tire.
To determine if it’s going to fit is a bit more difficult then that.
Every tire brand has a slightly different sidewall profile and just that can cause problems.
Your Pirelli may sit differently then my Falken.
Plus, you have a CL-P which may have slightly different suspension geometry then the “S”.
Most people here with aftermarket wheels are putting them on the Type-S.
Shawn S
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
