Can I use this supercharger
Old 07-21-2009, 09:27 AM
  #41
3.7L Nitrous Breathing CL
richardparker's Avatar
I'm going to go after this,If it dont excede 275.Think this will work for me.Seems like my best option so far.ZEX 82021 WET NITROUS SYSTEM plus EXTRAShttp://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 07-21-2009, 09:32 AM
  #42
wham bam thank you ma'am
Rajca's Avatar
That's gonna go for $400+. I got a dry kit and paid $600 plus all the extra stuff I got, spent over $1k for my system
Old 07-21-2009, 09:48 AM
  #43
Its selling for 500-600 new.275 is all I'm working with right now.This will work right?
Old 07-21-2009, 11:27 AM
  #44
Pseudomaniac's Avatar
I have the wet kit on my s2000. It has a single "dummy proof" box with line in for fuel and line in for N20 and line out for fuel and line out for N20. There are 2 leads for power, 2 leads for the TPS, and 2 leads for the arm switch. There is a light on the unit. You put it in learn mode to learn the WOT position, and then check to see if it's working at WOT by opening the butterfly all the way and listening for the solenoids to kick.
Nitrous shot is adjusted by nozzles that go into the injection port. You have a nozzle for fuel and a nozzle for N20. Mix and match sizes to get the level of HP you're looking for.
Dry shots are a bad idea - do a wet shot for longevity and peace of mind.
Without a heater, on the standard bottle, you should get 4-5 good 1/4 mile bursts at 60-75hp, and then some power increase in the additional 10-15 1/4 mile size burst. With a bottle heater, you should get 10-15 good passes on a single fill. Add a bottle heater, remote opener, pressure gauge, addiitional bottle, etc. You can get fancy with it.
Bottle is going to run about $35-$40 to fill up.
That auction looks to be the complete kit. You'll need some sort of thread tap to screw the injector into your intake, or just buy the P2R TB spacer, which has a port.
Old 07-21-2009, 11:32 AM
  #45
Rajca's Avatar
It will work if u know how to install it.
Old 07-21-2009, 01:20 PM
  #46
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,461 Likes on 3,055 Posts
Old 07-21-2009, 02:01 PM
  #47
slow tl..
gfrg88's Avatar
Originally Posted by Allout
lol - Can't argue that they're cheap though. And zero lag.
Zero lag, and boost will probably start dropping off at 3500 rpms on our cars lol
I would do the nitrous.. It's the easiest (if you know what you're doing) and cheapest route to get some good power out of your car.... I'm going to be getting a NX wet kit soon
Old 07-21-2009, 03:15 PM
  #48
thanks for the advise,you anwsered 2 of my questions in your response."how much does it cost for fill up's"and where's a good place to put the injection nossle. If I do win, I will probally asking questions.The spacer sounds like a great idea. Is the spacer already threded?
Old 07-21-2009, 04:49 PM
  #49
It's threaded, in the same thread that I'm sure some sort of nitrous kit uses - but not necessarily the ZEX. The guys at P2R could probably tell you for certain.
Old 07-21-2009, 04:57 PM
  #50
Rajca's Avatar
bottle refill usually run between $35 and $45 for a 10lb bottle. my p2r tb spacer has a threaded hole for a set system setup for the injection point. but since im dry, it have to but it about 8" from the tb.
Old 07-21-2009, 07:35 PM
  #51
well, no go on the kit,I got beat out 292.50.I was biding my ass off and time ran out.It sucks but I'm kinda glad, all I wanted to spend was 275 and it would've definitly went over 300 cuz I usally dont stop biding till I win.
back searching
Old 07-21-2009, 08:46 PM
  #52
Whats the differance between a dry/wet nitrous kit?
And wicth of these would be best for me.http://cgi.ebay.com/ebaymotors/ws/eB...m=180383136857
http://cgi.ebay.com/ebaymotors/ws/eB...m=200364435597
Give what ever info you can in helping me with a decission.
Old 07-21-2009, 08:54 PM
  #53
Rajca's Avatar
with a dry system u dont make as much power if u were spraying a wet shot with the same jet. u dont add fuel and nitrous like in a wet system u just spray nitrous and the fuel is added by the ecu. theirs a lot more to that but those are the differences. and dry shot is a lot, a lot easier to install
Old 07-21-2009, 08:59 PM
  #54
what makes the differance in the power? the jets. And if I want 75 should I be trying to make 100 dry?Gimmie the skinnie man,I'm trying to buy something NOW
Old 07-21-2009, 09:10 PM
  #55
Rajca's Avatar
the jet hp is to the engine, not the wheels. so auto and manual is diff in power. wet system will give more power bc it shoots nitrous and fuel and they atomize in the intake manifold and then the ecu also spray the normal amount of fuel and sucks in the normal amount of air, thus giving a better mix and more power. with a big enough shot (dont know the max on a wet kit) but u can max out the fuel pump. and theirs a lot more work, knowledge, and plumbing involved in this kit.
dry system just shoots nitrous and the zex system monitors the fuel pressure by reading off the fuel pressure regulator and that will add the appropriate amount of fuel, which isnt always the perfect amount and not making as much power as it can. u put the nozzle before the tb so the ecu can monitor the amount of air going in and add fuel if needed. if u shoot a dry shot and have a big enough jet (id say about 150) u will max out the injectors and or pump, and thats the step ppl skip and the engine goes to shit. my 125 dry is holding up good, i also installed a walbro 225lph fuel pump for safety measures
either way i have tons of fun with my dry kit, and beat some cocky ass kids. puts a smile on my face. gonna dyno the car this sunday
i can go on and on but im tired, just google what questions u have.
Old 07-22-2009, 07:24 AM
  #56
Spraying fuel with the nitrous also helps prevent the engine from blowing the tops off your pistons. N20 isn't rocket fuel, it's an oxidizer - basically it's presence allows the engine to breathe substantially more Oxygen in less time.
Remember the equation - fuel - fire - air. You change the air, you need to change the other two. Cooler plugs are a MUST for any large spray Nitrous setup (Zex makes some, but they're junk IMO) and you will lose a little power on the daily driving using them. Adding fuel to the spray mix keeps it from leaning out - though it's still possible to do so - just much, much harder.
Old 07-22-2009, 09:23 AM
  #57
Rajca's Avatar
Forgot about the spark plugs. I got the one step colder plugs. Been holding up great so far. What other spark plugs would u recomend?
Getting it tuned will help out a lot. I see my fuel drop down a lot when I spray. Kinda sad of how muvh fuel a 125 shot needs
Old 07-23-2009, 12:52 PM
  #58
I'm meeting a seller today from Craigslist for a zex dry kit 75-125.everything there,nice gauge and a set of extra jets from 50 -150.For only $200
What plugs are people running ?
Old 07-23-2009, 02:20 PM
  #59
You're also spraying a dry shot?
Old 07-23-2009, 03:04 PM
  #60
How and where do I find 1 step colder plugs?I dont know the heat range of my plugs now.I was told 1 step for under 100shot and 2 steps for over 100shot.
Old 07-23-2009, 03:43 PM
  #61
Rajca's Avatar
im spraying a dry shot. i got my plugs from zex.com
Old 07-23-2009, 04:22 PM
  #62
I checked the site,they only offer one plug option for about $32 a set.Are those the ones you have?Are they 1 step or two?
Old 07-23-2009, 04:27 PM
  #63
Rajca's Avatar
my plugs were about $56 two years ago and 1step colder
Old 07-23-2009, 10:09 PM
  #64
This is what I got for 220. I got the bottle,the box,the long line,a purge setup,6 jets and a couple of switches,and 2 bottle brackets.
And now that I'm home I dont have the short line or no nozzle.Is that all I'm missing.
Old 07-23-2009, 10:28 PM
  #65
slow tl..
gfrg88's Avatar
Nice! Can't wait to see how your car runs once you've got it in!! Good price too!
Old 07-24-2009, 04:39 AM
  #66
Rajca's Avatar
never worked around purge, so dont know what lines ur missing, i know that u need a foot and half or so line from the purple box to the intake.
never found a reason for purge.
Old 07-24-2009, 03:57 PM
  #67
CH46ESeaKnight's Avatar
Yes Yes, I can't wait to see the results either! lol This should be good!
Old 07-24-2009, 04:17 PM
  #68
Rajca's Avatar
Invest in a bottle warmer. Keep the bottle temp at the right temp for maximum power and longevity(spelling) I have sprayed 3 times at the track and a few highway runs. Still have over 750psi in one bottle. Also have another bottle, just in case
Old 07-24-2009, 04:55 PM
  #69
slow tl..
gfrg88's Avatar
bottle warmer is a must!!
Old 07-24-2009, 06:19 PM
  #70
I ordered the rest of what I needed last night from zex to install the setup.
How do we adjust the timming on our cars ?
Anyone else running a zex dry kit ? If so where did you put your mangement box.I can't find a good place.
Old 07-24-2009, 07:18 PM
  #71
Rajca's Avatar
U need a piggyback to adjust the timing on our cars. I didn't touch my timing and all good so far.
Check my project cl-s6 thread. I have pics towards the end of where I put my zex unit. Only good and easily reachable place for it
Old 07-24-2009, 10:19 PM
  #72
Is there anywhere to get a cheap piggyback controler ? the cheapest I've seen were atleast 300.
Old 07-25-2009, 06:48 AM
  #73
p.diddy's Avatar
something like that i wouldnt go cheap on. that being said i think 300 is as low as you will find.
Old 07-25-2009, 07:06 AM
  #74
Rajca's Avatar
Nothing cheap. Greddy emag or aem fic
Old 07-25-2009, 11:14 AM
  #75
Witch wire should I be tapping into for the tps.If anyone can produce a pic that would be great.
Old 07-25-2009, 11:25 AM
  #76
Rajca's Avatar
Ill take a pic when I get out od the hospital (maybe today or Monday). If u have a volt meter u can turn the ignition on and poke the wire then open thew throttle all the way. Should read just below 5v
Old 07-25-2009, 12:03 PM
  #77
Do you remember the color of the wire?
Old 07-25-2009, 12:10 PM
  #78
Rajca's Avatar
Don't remember the wire color. Maybe u can find a pic of it on my progress thread.
Old 07-25-2009, 01:19 PM
  #79
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,323 Likes on 4,900 Posts
The middle wire is the one that reads the voltage from .5v (closed) to 4.5v (open).
Old 07-25-2009, 01:38 PM
  #80
Thanks civic.I only want to wire it once.
Quick Reply: Can I use this supercharger
