Camber kit after these alignment specs?
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
So I brought my car two weeks later after a h&r drop and tokico shocks to get it aligned. They got the boot and caster back to specs and the camber back to specs in the front.
The rear left camber is -1.14 degree and right rear is -1.44 degree....it says should be from -1 to 0 to meet specs. Is this .14-.44 degree variant enough to warrant a camber kit, because I really dont want to put down the money for this...or will my tire wear be okay, since the front is the one wear the tread really gets shot. Thanks
COME AT ME BRO!
get a camber kit i droped my cl and went threw tires like there was no tomorrow. i had the ingalls kit put o deffently worth the money. other wise you will spen twice as much by replacing tires if you have nice ones anyway
Originally Posted by sgmotoring
How is the front?
Yea Im thinking I will let it go...i dont even know what camber is so I cant tell that it looks any different than before hand? But they said they got the toe and caster back to spec.
Since the back tires hardly wear I guess I wont do anything and see if the inner tread of the back tires wear a lot more prematurely...since I drive hard I only get about 10-12k out of my all season conti's anyhow.
If I do decide to get a camber kit which one should I get and where...also what price should I expect to pay?
There is a good article here on alignment and a description of camber towards the top:
http://www.tirerack.com/tires/tirete...eral/align.jsp
As for the proper camber kit to choose, well it depends on how bad the camber is on your car.
Speciality Products and Ingall's make some of the best kits. Eibach also provides some alignment kits. Each kit provides a different level of correction. So in order to buy a kit you'd first need to know how bad your camber is, and then purchase the kit that would provide the correct level of correction. So if you hold out right now on buying a kit, you'd have to later on get your alignemtn done so you can know what kit to buy, then buy the kit, have it installed and then have the camber corrected.
Do a search on here for both and you'll see what other's have put. or go to
http://www.comptechusa.com
http://www.neuspeed.com
http://www.c-c-c.net
to look up the camber kits.
Thanks, as you know I just got my alignment the springs are settled and I dobut the camber would change much at all....
On the rears its -1.14 and -1.44 degrees so it doesnt need a big correction.
On my last car which was an integra gs-r, i installed Progress 2.2" springs.
over the years they settled to be about a 3"+ drop
so springs never stop settling. But the rate at which they settle depends on how much you drive, and how you drive your car.
WTF damn I wish I knew that before getting the h&r then, I would have went with something more slight...I thought my springs would settle at around 1.95/1.7 but since I am going to have this car for a while I dont want it on the ground in a few years
no they arent but install prices arent that great around here, but I thought the h&r were powdercoated or some shit to reduce sagging and last without losing responsiveness and bouncing a lot.
DUDE... don't worry about that! It's not like they are going to sag an addition inch in a few months. Over tens of thousands of miles you might notice the springs have settled more. But it is nothing to worry about. It's not like the car is going to be resting on its bumpers in 3 years.
Chill out
i forgot to include the cost of spring install. yea for replacing springs with labor you're looking at 400 bucks usually depending on what spring you go with + install. so that can add up, but again, it depends on how much you drive your car and how you drive it.
honestly I wouldn't worry too much about spring settling. but at least be aware that over time they will continue to settle. You should be alright if you want to wait on getting your camber kit, but keep a good eye on it. because before you know it you'll have a set of worn tires and then you have to replace your tires and get a camber kit which will be even more expensive.
Can your provide info on the claim "springs never stop settling"? I have been told by countless suspension people springs do not settle past what they are supposed to drop the car by. Comptech has stated their springs don't settle at all cause they are engineered to the weight spec of the car at each corner. Not trying to start anything
just curious as to where this comes from?
Your sure your not confusing this with wearing out your springs? Over time yes springs wear out like any other part. However that takes a ton of miles.
In any case I wouldn't be worried about it Renegade, & just enjoy the car.
Don't worry about stating somethin, I dont see it as trying to start something, i'm probably gonna learn something new outta this....
I see your point about springs not settling past a certain point; however, as the springs wear out (over a long period of time) doesn't metal fatigue on the spring cause it's ability to hold a certain amount of tension decrease over time? I would think that is the case no matter how well you manufacture a spring. The only difference of course would be, like you said, the springs are manufactured in such a way that they will last a longer period of time.
Maybe someone on the board that's has had comptech springs on their car, or another brand could chime in on how their springs are performing today compared to when they first installed them if they installed them a couple years ago or more (i smell a new thread being possibly started) but since the 2nd gen CL is only 3-4 years old we may not have all the info we want to figure this out.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
H&R and Eibach heat treat their springs to prevent much spring settling. But rascal is right, after a few years they seem to lose their step a little
My sportlines definately don't perform like they use to
MrHeeltoe
79
10-14-2015 08:47 AM
nuldabz
09-03-2015 05:49 PM
