camber kit...
Old Jul 22, 2001 | 07:14 AM
2001CLTypeS's Avatar
camber kit...
HI,
its 3 months after i had the eibach pro-kit installed on my cl.
i am going to get alignment done to it, some people said it might be able to get it within factory spec. Is it true?
also, i want to get camber kit. What brand is good and do i need front camber kit or back or both? can i get it install when they do the alignment?
Thanks alot.
-2001CLTypeS
Old Jul 22, 2001 | 07:51 AM
FDao's Avatar
Originally posted by 2001CLTypeS:
<STRONG>HI,
Thanks alot.
-2001CLTypeS</STRONG>
With a camber kit, you will be able to get to factory specs. Ingalls makes a kit for our CLs, and you can get it installed prior to the alignment. Check www.autocarparts.com .
Old Jul 22, 2001 | 08:01 AM
Satin Slayer's Avatar
aka gimmesomesugar
How can you tell if you need a camber kit?
Old Jul 22, 2001 | 08:26 AM
FDao's Avatar
Originally posted by Satin Slayer:
<STRONG>How can you tell if you need a camber kit?</STRONG>
An alignment will tell you how much negative cambers you have compared to stock after lowering your car. In most cases, camber that is off by .1-.3 may get away without a camber kit.
Old Jul 22, 2001 | 08:32 AM
amir was here's Avatar
how much are camber kits?
Old Jul 22, 2001 | 08:39 AM
FDao's Avatar
Originally posted by amirsafdari:
<STRONG>how much are camber kits?</STRONG>
Check out www.autocarparts.com .
Old Jul 22, 2001 | 08:56 AM
Originally posted by FDao:
<STRONG>
Check out www.autocarparts.com .</STRONG>
thanks.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
0opie
Sep 22, 2015 04:15 PM
