Camber Correction kits?
Old Feb 18, 2001 | 10:13 PM
Jayru's Avatar
I was on Autocarparts the other night and ran across something called a camber correction kit. It looks like a short rod.
Is this what is used with the comptech springs? Will this re-adjust the camber on the rim/tire to prevent the wear of the tire quicker?
I'd love to get springs and rims, But, I drive over 80 miles a day and do not want to go through tires any quicker then I have to..
Any thoughts?
Old Feb 18, 2001 | 10:23 PM
MikeS 18's Avatar
Adult Supervision
I emailed back and forth with Tim and Comptech and here is the word on that: there is a set for the rear of the CLS bt not yet a set for the fronts, they are still being developed. Comptech however thinks that the CLS will not require a camber kit as the springs do not lower the car enough to through it out of spec. Most of the results which we have seen here prove this theory. Eitherway, you do not have to install the camber kit with the springs so you can wait and see how the alignment comes out a couple weeks after installing the springs.
CL-S #22,299 Black/Parchment/Nav, spoiler, door & fender guards, wood trim, PIAA 19169 & 9005, V1 w/remote, trunk & winter mats, no headers, no sway bars, no springs, no money!
Old Feb 19, 2001 | 12:48 AM
CL-Super's Avatar
Who's Your Daddy
the comptech springs do not lower the car enough to affect the alignment of the car...so the camber kit is not needed...if you get the springs installed at an Acura dealership they will even warranty the suspension...camber correction kit is only needed for 2" or lower and if you do this the factory suspension warranty is void.
Old Feb 19, 2001 | 11:33 PM
Jens H.'s Avatar
retired
Correct the camber kits thus far have not proven to be required on Comptech springs.The toe settings on TL/CL's are what needs to be reset after the car is lowered.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
0opie
Sep 22, 2015 04:15 PM
