For CAI owners, this setup really protects the pipe
'Cooter
i remember a few weeks ago, i described the setup i used for my intake to protect it from scratches/punctures...here's a pic that shows how i did it
for AEM owners, this is a good alternative to using the brackets if yer worried about them snapping
the black ring is from the stock airbox...i hope this helps
4dr & I like it that way
hey BlackShadow watd you do about that bolt on the CAI thats in front of the shock (the upper one you see in that pic) on your car? The one AEM sent with my intake is too small for our 99's so I've had that support loose (CAI is stil held in securely by the other bolt, but its annoying to not have both as the CAI vibrates quite a bit)
also you can use the stock upper box and then cut a hole in the lid ,,, you can now mount the cable back in it's stock location.... note don't make the box air tight,,, the valve won't work
Originally posted by Shawn S
What’s the big deal?
That’s a standard Xephyr CAI install.
'Cooter
Shawn S
Shawn S
Puma Jim
20
10-20-2016 11:59 AM
IIDXholic
10-08-2015 07:53 AM
09-17-2015 09:01 PM
