Buying comptech headers tonight.. I NEED YOUR ADVICE
Old 09-21-2009, 02:55 PM
  #41
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,464 Likes on 4,982 Posts
Get all new gaskets. The j-pipe to cat gasket you can get at an autoparts store. Just bring the old one with you.
Old 09-21-2009, 03:16 PM
  #42
lowrd on tein CS biatch
CL-S progression 01's Avatar
Got the stuff.. wrapped the headers.. DAMN this shyt takes a long time. I did it this time without wetting it and it was easier in my opinion. I put it on as tight as it could be put on . period .
And I left the lil comptech badge sticking out to see love it.
Now I just need to wait for my damn j pipe to dry the F out.
ok so the cat gasket is 2.5" ?
and the 2 headers ones are 2.25" ?
and then 6 32 by 10 mm bolts?
someone correct me if i am wrong plz.
Just need to grab those pieces and then spray the header set with the silicone stuff and let that dry for a day or so and then voila... ready to rumble.
Friday is my goal to hit.
Old 09-21-2009, 05:02 PM
  #43
civicdrivr's Avatar
I believe you are supposed to wet the header wrap so it goes on tight.
Old 09-21-2009, 06:57 PM
  #44
yea I did that and it just makes things harder. I did it for the J pipe but the headers I did dry and it turned out better.. And it's a lot CLEANER..
Anyways so tomorrow I spray the shit outta the header system. then I'm gonna install it on weds or thurs prolly!!!
got the bolts and the 3 gaskets for $16.92.
The 3 o ring gaskets are 2.5" in case anyone was wondering.
I will post the results when its done..
The car alreadys breaks the tires loose in gear when the roads are just a LITTLE bit wet...
mmm mmmm sexy this shall BE.
Old 09-21-2009, 07:12 PM
  #45
Will I BE OK??? please please
So I decided to take both of the header flanges and put them together to see if they lined up 100% flawlessly and they ALMOST do.. but they're off by i'd say approximately 1mm or so.
Will this cause a problem?
Or will this all be irrelevant as I tighten down the bolts on the headers to the heads??
PLZ tell me it's ok
THE LAST thing I want is a frigging leak from all this damn money and work i've been putting into my car.
Can someone please shed some light on my issue so i'm no freaking out here
SERIOUSLY APPRECIATED..
Old 09-21-2009, 07:21 PM
  #46
wham bam thank you ma'am
Rajca's Avatar
never heard of that. i put mine on dry and kept the wrap tight. doesnt move at all.
op, r u using metal zip ties to hold down the wrap at the ends? please dont use the circle type clamps (hose clamp), or the plastic zip ties.
Old 09-21-2009, 07:27 PM
  #47
hahah yes I am using the ones that come from DEI and I used a shit load of them to make sure nothing moves.
Like I said I am not going to do this a second time..
Question is it ok is my header flange (where it meets the heads) is off TRUE by like 1 millimeter ??? literally like a millimeter?
That will become flush when I bolt it down to the engine correct??? or am I screwed?
Please tell me it'll go flush!!!!
Old 09-21-2009, 07:29 PM
  #48
Rajca's Avatar
u will have some play with it.
Old 09-21-2009, 07:36 PM
  #49
have some play??? howso I'm talking about where the 3 primaries come from the main flange off the heads. That fange is off by roughly 1 millimeter.. well when I line both of the 2 together there is a 1 mm gap..
that should bend true right?
Old 09-21-2009, 07:39 PM
  #50
1 mm as in when it sits flat on the heads my guess is one side will be like 1 mm off the heads... so when i bolt that down it'll go flush..
RIGHT?
Old 09-21-2009, 07:52 PM
  #51
Rajca's Avatar
the bolts will compress it down. and with the gasket it will be all good.
Old 09-21-2009, 08:13 PM
  #52
Rajca's Avatar
u will be fine. but no need to start a new thread. just post it in ur other two header question threads
Old 09-21-2009, 08:14 PM
  #53
wooooosssssaaaaahhhhhh!!!!! that's what I assumed but wasn't positive of. thankyou
Old 09-21-2009, 08:18 PM
  #54
OG 3.x^7 rawr
SPoolinspOON's Avatar
you should be fine. you can also take it and throw it on a belt sander to flatten it.
Old 09-21-2009, 08:21 PM
  #55
p.diddy's Avatar
lol
Old 09-21-2009, 08:36 PM
  #56
HEAVY_RL's Avatar
Received 1,043 Likes on 848 Posts
LoL, i see an epic merge coming.
Old 09-21-2009, 08:38 PM
  #57
civicdrivr's Avatar
Make sure when you install everything you dont tighten all the bolts until you have everything together, that way you still have play with everything.
Im sure you know that though
Old 09-21-2009, 09:00 PM
  #58
Rajca's Avatar
^i could have sworn that i read that a min ago in a diff thread. what a coincidence.lol
Old 09-21-2009, 09:05 PM
  #59
civicdrivr's Avatar
Lol.
Old 09-21-2009, 10:12 PM
  #60
OG 3.x^7 rawr
dab some anti-seize on the head studs when you reinstall the comptech headers
Old 09-22-2009, 06:45 AM
  #61
I have literally NO cash left on hand guys. I spent every dime I got on everything or the headers.... And I just woke up to find I have the DAY OFFF
FUCKING RIGHT... Headers will be on today PEOPLE!!!! result will be posted tonight.
Given it doesn't poor buckets or rain here
Old 09-22-2009, 07:35 AM
  #62
these things KEEP smoking up my damn KITCHEN!!!!
anyone know how long to bake them for?
till they stop baking? LOL
Old 09-22-2009, 11:54 AM
  #63
HEADERS are on... just cleaning my hands and tools in the driveway!!
car sounds AMAZING... revs better too
Haven't gone for a drive yet THO.... OHHH SHIT this is ill
I'd just like to say THANK YOU to all who responded to my 1000 questions and posts..
THANK YOU. It could not have gone better.
I did it myself in 2 hrs and 20 mins
The rear header bolts are a bitch to get back on!!! FYI
BUt thanks AGAIN WOOO COMPTECH
Old 09-22-2009, 12:30 PM
  #64
Rajca's Avatar
Its not a test drive, its a test beat
Old 09-22-2009, 01:52 PM
  #65
Rajca's Avatar
Old 09-22-2009, 01:57 PM
  #66
Your Garage
DC3328's Avatar
lay off the red bulls
lol
Old 09-22-2009, 02:05 PM
  #67
alright I went for a spin and the car is simply not what it was b4 it's a friggin beast now!. tires are trying to break traction in 2nd if you turn at all at like 4500-7000
* no red bulls today
Old 09-22-2009, 02:32 PM
  #68
civicdrivr's Avatar
See what youve been missing out??
The headers were one of the first things I did to the car. Did you reset your ECU before the test drive?
Old 09-22-2009, 02:54 PM
  #69
no why is that crucial? how does it matter
just unplug the battery?
fo a second I head the nastiest exhaust leak but it was this altima behind me!! hhaha whewww
Old 09-22-2009, 03:25 PM
  #70
civicdrivr's Avatar
Its not crucial, just speeds up the relearn process. You changed the configuration of the motor, and the ECU now has to relearn the parameters. Its quicker for it if you reset it, but as I said, its not crucial.
Old 09-22-2009, 03:39 PM
  #71
k. then forget it.. let her figure it out. I can't complain with the results so... lol i leave it B
Old 09-22-2009, 04:14 PM
  #72
civicdrivr's Avatar
Might as well. Is your track still open? If it is, you should try taking another pass to see how much you gained.
Old 09-22-2009, 04:25 PM
  #73
i am going to the drag strip next week or 2 weeks after that... I'm not sure.
It's a shit load of pick up added... like 100-160(kms) is a WHOLE different story
Old 09-22-2009, 06:01 PM
  #74
p2r thermoblock gasket will be done in 1 hr. I'm on break
Old 09-22-2009, 06:43 PM
  #75
Rajca's Avatar
sucks that u dont have a 6spd. that thing will rip
Old 09-22-2009, 07:35 PM
  #76
i like just cruising man.
thermo gaskets and tb gaskets are ON
Old 09-22-2009, 07:55 PM
  #77
p.diddy's Avatar
me too.
Old 09-22-2009, 08:02 PM
  #78
yo the termo gaskets made a DIFFERENCE
I can tell just by the temp of the manifold! LOVE P2R... anything they make I must have
Old 09-22-2009, 08:17 PM
  #79
Rajca's Avatar
its good stuff. did u reuse ur old metal gasket thats between the runners and IM and the thermal spacer? or u just used the thermal spacer?
Old 09-23-2009, 06:21 AM
  #80
JUST used the spacer... and it works amazingly.. no problems.
No tq wrench used for the headers or the manifold too. and everything is working 100%.
I was debating to reuse the metal intake manifold gasket but opted not to.
I also re-used my exhaust gaskets too and they sealed perfectly!!
fucking I love comptech, that god I had NO snags. No fucked up bolts or nothing. Just smoothing sailing.
Quick Reply: Buying comptech headers tonight.. I NEED YOUR ADVICE
