burnouts
Old Jul 29, 2001 | 12:25 AM
wariatnumer1's Avatar
burnouts
does anybody know how to do burnouts on a cl-s.
can you tell me.
does anybody have any videos of burnouts.
can i turn off my traction control.
if i can, how?
_____________________________________________
2001 Acura 3.2 CL-S
--comptech headers
--comptech axle-back exhaust
--comptech springs
--comptech sway bars
--aem tru power pully kit
--aem cold air intake
--denso spark plugs
--kaaz limited slip differential
--piaa super white bulbs
--neuspeed front upper strut tie-bar
--pirelli p7000 215/50-17 tires on stock rims
------0-60 in 6 sec. and 1/4 in 14.4 @ 99.6
[ 07-28-2001: Message edited by: cl-s-pimper ]
Old Jul 29, 2001 | 12:52 AM
Rescuer's Avatar
Evil Bob Knieval
i've raced my car at the track, but what i did was just put the ebrake all the way down, and slam the gas for about 5 seconds
Old Jul 29, 2001 | 01:12 AM
89si's Avatar
Push the VSA button (on the left side of the steering wheel next to the moon roof controls) when the light is on your good to go. You'll see the "!" in the triangle glowing yellow.
Old Jul 29, 2001 | 01:13 AM
so does it actually smoke up the tires when you do that.
Old Jul 29, 2001 | 01:19 AM
z28typeSWRXkid's Avatar
if you hold up the ebrake it sure will...we arent that void of torque
Old Jul 29, 2001 | 01:20 AM
does anybody got a video of a good burnout with their cl type s
Old Jul 29, 2001 | 01:46 AM
so any burnout vids out there
even for any car
Old Jul 29, 2001 | 09:53 AM
does it wear a lot of tires if you do a burnout like that and again does anybody have any movies on burnouts
Old Jul 29, 2001 | 10:22 AM
KCPreki11's Avatar
Originally posted by cl-s-pimper:
<STRONG>does it wear a lot of tires if you do a burnout like that and again does anybody have any movies on burnouts</STRONG>
Not that i doubt you, but i must ? u not knowing how to do a burnout in a car. with all you mods u got u have to know something about cars???
No videos i dont think, it will wear out the tires faster than normanl use
Old Jul 29, 2001 | 12:48 PM
typeR's Avatar
especially you're the first one to have the LSD installed hum???
[ 07-29-2001: Message edited by: typeR ]
Old Jul 29, 2001 | 03:35 PM
VTECnology's Avatar
must be a prototype cause I just got off the phone with Kaaz. seems there is no LSD for sale yet. they said they have no plans to develope one either. that's impressive, wonder how much a one-off LSD cost
Old Jul 29, 2001 | 04:19 PM
why don't you guy believe me about the limited slip diff.
no i can prove you wrong
look on www.autocarparts.com
___---___
KAAZ Limited Slip Differentials (?.S.D.· react fast without fail and have a wide range of adjustments available to suit different driving conditions. We use the largest friction plate size possible and also increase the number of plates to gain maximum performance.
The sensitive L.S.D. will work even when the slightest torque is applied.
Increased ability to transfer power from the engine to the wheels without loss of power.
The power acting on the plates is reduced so that abrasion on the plates are protected.
Increased number of friction plates greatly improved abrasion efficiency and heat capacitance of the plates.
Not only the friction plates, but all parts of our L.S.D. have been improved and made larger, so the overall strength of the main body is increased.
All years Acura (All Models)
Notes: Kaas Conversion from 1.5 way to 2 way for full differential action under braking. Requires full teardown of Kass unit to install.
Our Price:
$166.50
Shipping: $60.00
Old Jul 29, 2001 | 04:30 PM
KCPreki11's Avatar
<STRONG>why don't you guy believe me about the limited slip diff.
___---___
Our Price:
$166.50
Shipping: $60.00</STRONG>
Yea i think someone else asked us about another L.S.D. and the solution came up not to get for a reason i forget, they said it was mostly for a certain type of racecar?
Old Jul 29, 2001 | 04:38 PM
ChodTheWacko's Avatar
Moderator Alumnus
I don't know much is 'a lot' but burning out certainly isn't fantastic for your tires.
I don't sweat too much over it unless you do it ALL the time.
Torque-braking isn't the greatest thing for your car either, but hey.
Old Jul 29, 2001 | 05:44 PM
Technique's Avatar
Put the car in reverse, roll backwards at about 5MPH, then switch the car into drive real quick and smash the gas. You'll go a nice burnout
Old Jul 29, 2001 | 05:57 PM
Achance's Avatar
Coming to a city near you
doing burnouts on radial tires is counter productive. All you will do is get the tires hot an greasy. You should only be doing burnouts on slicks. Those tires need to be heated up to become sticky. All you need to do to radial tires is let some of the air out of the tires(to increase contact patch), and do a quick spin to knock the rocks out of the tread. And if you are at the drag strip AVOID the water box if possible. It is always funny to watch a civic roll into the waterbox and spin his tires because other people are and then at the light tree all he does is spin tire and can't figure out why he isn't going anywhere.
But if you just what to burn tire on the streets just for fun, then turn off VSA and torque brake. And when you release the brake make sure you turn the steering wheel back and fourth quickly to try to get the other tire spinning too. Otherwise only one will be spinning. And try to do it in the rain at a parking lot that way you will have less traction and plenty of room.
Old Jul 29, 2001 | 06:58 PM
charliemike's Avatar
Fahrvergnügen'd
Originally posted by Achance:
<STRONG>doing burnouts on radial tires is counter productive.</STRONG>
I think he wanted to be a l337 d00d and do burnouts in his car. I didn't get the impression he was actually ever racing.
Old Jul 30, 2001 | 02:28 AM
dlew308's Avatar
burning out will eat up the tires nice and fast...and if burn out while racing, well
stick in reverse and go home in shame.
burn out with slicks after you roll over water...do not go over the water on regular tires...it's not fun spinning in one spot hehe
Old Jul 30, 2001 | 03:06 AM
CLpower's Avatar
teh Senior Instigator
Old Aug 1, 2001 | 02:51 PM
will my car burnout when i just put the e-brake on and just floor it.
why do i need to turn the steering wheel when i burnout so both tires spin.
i would also like to know if anyone got pix or videos of their car peeling out.
[ 08-01-2001: Message edited by: cl-s-pimper ]
Old Aug 1, 2001 | 02:57 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
<STRONG>
[ 08-01-2001: Message edited by: cl-s-pimper ]</STRONG>
Yes, because we have an open differential that puts most of the power to the tire with least resistance...by turning the wheel...you alternate between each tire...or you'll just burn one out.
On the matter of the LSD.....Kevin was talking about a group order from Quaife. Expect at least 1K per with a minimum of 10 orders before Quaife will build it.
On the Kaaz...you NEED THE ENTIRE TRANSMISSION UPGRADE BEFORE YOU CAN INSTALL THAT LSD. No LSD is $160....trust me...
Old Aug 1, 2001 | 03:03 PM
phil2's Avatar
has Gloryhole Girls in
here is the link of a burnout clip
http://www.3rotor.com/video/jc2_burnout.mpg
:p
Old Aug 1, 2001 | 03:09 PM
TypeSKid's Avatar
All these fucking mods, yet still unable to do a burn out?
Can I raise the BS flag yet?
Old Aug 1, 2001 | 03:13 PM
phil2's Avatar
this one is even bettah!!!!!!!
http://www.3rotor.com/video/20b.mpg
yo check it OUT
Old Aug 1, 2001 | 03:19 PM
BSK181's Avatar
time for the flag
Old Aug 1, 2001 | 03:20 PM
BSK181's Avatar
i need some help too, when i go to get laid, is there a special way to put it in, can someone send me a video, i am only 50 and am new to this stuff!!!!!!
Old Aug 1, 2001 | 04:04 PM
Nugs3's Avatar
BURN OUTS AND FUN http://streetracing.com/media/videos/10/3052001_2.asf
Old Aug 1, 2001 | 05:13 PM
im not bullshitting because i did many burnouts but they weren't that big because only one tire was spinning.
i was just asking how to spin two tires.
Old Aug 1, 2001 | 07:56 PM
KCPreki11's Avatar
<STRONG>im not bullshitting because i did many burnouts but they weren't that big because only one tire was spinning.
i was just asking how to spin two tires.</STRONG>
Weird, both should spin, do u have stock tires??? make sure VSA is off
c'mon, i mean cl-s burnout videos and if no one has them can you try doing them and then putting it on this site.
i would do it but i don't have all the hardware to do it.
Old Aug 1, 2001 | 08:02 PM
KCPreki11's Avatar
<STRONG>c'mon, i mean cl-s burnout videos and if no one has them can you try doing them and then putting it on this site.
i would do it but i don't have all the hardware to do it.</STRONG>
no one has any time for u
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
CLpower
May 11, 2006 08:37 PM
rise
Console & Computer Gaming
27
Jan 21, 2005 04:07 PM
