Brake Rotors???
Old May 17, 2004 | 02:07 AM
CL FWD SPEED's Avatar
What to do, what to think
Brake Rotors???
I'm deciding to get these front rotors soon from comptech...what do they mean "Not For Racing"? will these rotors effect the offset like the brembo kit?
http://solar.innercite.com/comptech/460112ltl.html
Old May 17, 2004 | 02:36 AM
NiteQwill's Avatar
Adventurist.
No offset difference, they are stock size. The "not for racing" is because they will not withstand the heat of doing so.
Old May 17, 2004 | 09:16 AM
sushimaster's Avatar
$135 each rotor for the Comptechs.
I'd rather get the Brembos. $246 a pair.
http://www.brakeworld.com./catalog.a...275&invidtype=
Old May 17, 2004 | 09:48 AM
Bluto's Avatar
Find beauty in dissonance
I just ordered these:
http://www.streetbeatcustoms.com/rot168400460.html
http://www.streetbeatcustoms.com/rot168400520.html
$302 for front and rear shipped. Going to use Acura pads, about $90 front and rear. I don't need metallic pads.
I replaced my brake fluid last weekend. Front pads were very low, front rotors need replacement, not warpped just thin.
Old May 17, 2004 | 10:50 AM
wow the brembo rotors looks great . are the brembo's the same size fitment as the OEM rotors and do I need to replace my brake fluid if I change the pads and rotors?
Old May 17, 2004 | 11:48 AM
Bluto's Avatar
Both are OEM Size. Bella & dj5 have the Rotora:
http://www.acura-cl.com/forums/showt...t=rotora+brake
1killercls has the above Brembo:
http://www.acura-cl.com/forums/showt...ighlight=brake
Other members probably have them as well. Maybe they can give evaluations.
Other than drilled/slotted, I don't know if they are the same Brembo Tirerack sells:
You don't 'have' to change your fluid. But most dealers recommend it at 45k (and charge $100). I think the owners manual states 60k or 90k? It is cheap insurance and not that difficult.
Jens H.'s instructions for stainless brake lines and changing fluid:
http://www.acura-cl.com/forums/showt...hreadid=118783
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
