Brake fluid ques
Acura TLS are SLOW
Originally Posted by NiteQwill
All brake fluid is generally the same price. You can get ATE Super Blue, Motul, or Motul Gold. I use a Motul DOT 5.1 in my car.
I dont think that our brake system is compatible with DOT 5.1
When i changed my Brake fluid, i just went with Honda DOT 3
Meat stick
Originally Posted by dj5
I bled the brake fluid in my '02-TLS and replaced with Vavoline Synthetic. It is Dot3 & Dot4 compatable and easy to find.
2001 J32A2 6Spd Accord EX
Motul Dot 5.1 would work. I have Motul Dot5.1 in my accord and it works great and i'm sure that the CL's brake system is the same (except for some minor differences). Dot 5.1 is a non-silicon based fluid. Not to be confused with Dot 5.0 (silicon based fluid).
Adventurist.
If I did something wrong, I'm sure my car would not be working right now.
![what](https://acurazine.com/forums/images/smilies/what.gif)
Adventurist.
Originally Posted by JaredGMS
Do you first completely bleed the lines, and then replace with new fluid, or do you slowly add new as you are in the process of bleeding the old?
I do my own work.
Originally Posted by tweedle99
I never remove the old fluid, just start bleeding and keep filling the master cylinder. When the fluid turns clear, you'll know that the old fluid are out.
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
