Bouncing Exhaust
Old Sep 25, 2007 | 03:59 PM
jacksonlan33's Avatar
Bouncing Exhaust
Friend was driving my cl-p today on the freeway while i followed in my friends van. I noticed my exhaust bouncing up and down. Is that normal? Or is there a way to prevent that? I also noticed my buddy's IS250 does the same thing, but a lot worse. Looks like the car is about to fall apart.
Old Sep 25, 2007 | 04:07 PM
underst8's Avatar
140,000 miles young
Was it the right exhaust? The right exhaust on our cars hangs lower over time, and will bounce a little.
It is normal for any exhaust to move around a little bit. Can you describe the "bouncing" in more detail?
Another exhaust topic - what do you guys think of these?
http://cgi.ebay.com/ebaymotors/GT2-M...QQcmdZViewItem
Worth the grand experiment? I'm eventually putting XS headers on, high flow cat and resonator as well. I was looking at Flowmaster muffs like everyone likes. These just caught my eye as not being the usual eBay loud-ass nightmare.
Old Sep 25, 2007 | 04:10 PM
Angry
It starts bouncing up and down when the road gets a little rough on the freeway. I would say a good 1-2 cm bounces. It just looks kinda ghetto. and its both of them.
Old Sep 25, 2007 | 04:16 PM
underst8's Avatar
140,000 miles young
Normal. I'd only get worried at like 2+ inches, or if it was so bad I could head it smacking the bottom of the car.
Welcome to the board too man. What color CL-P do you have?
Old Sep 25, 2007 | 04:37 PM
nighthawk black. a big hassle to take care of and very sensitive to fingerprints. i slapped on some 01-02 type s wheels. i also plan on changing the exhaust, somewhat like the type s, thicker muffler tips. i do not like the typical round shaped ones. any ideas how i can get that done?
Old Sep 25, 2007 | 04:38 PM
LIPPSTUH's Avatar
Unregistered user
there's a cheap mod to keep it from wiggling
search "wiggling exhaust"
Old Sep 25, 2007 | 04:46 PM
LIPPSTUH's Avatar
Unregistered user
edit: can't find the thread, i saw it on which linked a cl thread. basically you buy a thing that looks like a metal zip tie... i believe it's for pipes. then u take off your rubber piece for the hanger, you put the zip tie around it and tighten it,, then u reinstall it. it should cost you a bit more than a dollar for 1.. so i'm guess 3-4 bucks =D
Old Sep 25, 2007 | 05:20 PM
1HOTCLS's Avatar
Drive it like it's HOT!
aka "hose clamps" works like a charm...
Old Sep 25, 2007 | 05:30 PM
LIPPSTUH's Avatar
Unregistered user
lol zip ties, hose clamps... HEY at least you knew what i was talking about =P... i just found out about 2 weeks ago while driving my friend's car that our exhaust wiggle sick...
Old Sep 25, 2007 | 05:31 PM
thank you guys for the info. now about my exhaust tip question. i want the type s muffler tip, but maybe something a lil bit bigger with the same shape. could i get that done at the shop? how much would it cost?
Old Sep 25, 2007 | 05:34 PM
i use to live in arcadia now ive moved to alhambra. lipstuh did you attend ahs?
Old Sep 25, 2007 | 06:25 PM
underst8's Avatar
140,000 miles young
I too have a NBP (Nighthawk Black Pearl) Type-S (01 - so the wheels you have haha). It is a bitch to keep clean, out here in MN I am basically gonna fuggettaboudit from Mid Nov - Feb.
You can put pretty much any shape tip you want on any exhaust. You just buy the tip and then have a local exhaust shop cut off your old one and weld on the new one. If you buy say a flowmaster exhaust you can get one with no tip and then have the shop just weld on your tip of choice. That is what I would do - tipless flowmaster with a custom tip.
Old Sep 25, 2007 | 06:43 PM
MSW 6SP's Avatar
If you decide to go the zip-tie route, make sure they are aligned when your car comes off the lift. Only speaking from experience...i used zip ties on one of my mufflers and it was perfectly straight on the lift, but when I brought the car down the exhaust slightly shifted.
Sounds to me like your exhaust mounts are worn out...which is typical. Instead of buying new rubber mounts search online and buy polyurethane mounts.....those wont wear out over time like rubber does.
Old Sep 25, 2007 | 08:01 PM
Allout's Avatar
Blown is Best
DIY on aligning CL mufflers by Mattg. Using the hose clamps will also reduce the bounce by eliminating the excess stretch of the rubber isolators:
http://www.acura-cl.com/forums/showthread.php?t=157356
Old Sep 25, 2007 | 09:33 PM
Stealth CL's Avatar
proffesion...axle breaker
hose clamps FTW. work like a charm
Old Sep 26, 2007 | 11:00 AM
LIPPSTUH's Avatar
Unregistered user
i actually live in temple city but i put arcadia b/c a lot of people never heard of tc. i went to tchs.
Old Sep 26, 2007 | 02:03 PM
New Image's Avatar
B A N N E D
mine were so bad cuz of the super stiff coilovers and would smack the under carriage constantly. finally had new hangers welded on with super stiff rubbers
joflewbyu2
Oct 8, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
ivan06106
Sep 26, 2015 04:38 PM
