Both driving lights are out!
Old Nov 15, 2002 | 03:35 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I just found that both the driving lights are out...
Why they are both out? if one is out, does the second one goes out too?
If not, is it a fuse that is out? is possible there is problem in the wiring?
First, I will try to put back the stock ones... if they do work, I will go buy PIAA 19224 for the driving lights and 19225 for the reverse lights..
Old Nov 15, 2002 | 07:22 AM
SilverBullet_RENAMED's Avatar
You still have the headlights installed right?
Old Nov 15, 2002 | 07:24 AM
Happy CL-S Pilot
last time I checked, I do not live in Bronx... nor anywhere near NY.... I am clean...
Old Nov 15, 2002 | 08:25 AM
limuas22's Avatar
I'd rather be golfing
Re: Both driving lights are out!
If one of the driving lights go out the other one still should work, I had one of mine blow and the other still stayed on. I'd replace both bulbs with ones that work and see what happens, then I'd check the fuse if that didn't work. Also definitely get the PIAA 19224's, they look great compared to stock.
Old Nov 15, 2002 | 08:29 AM
CO-CL-S's Avatar
Most likely you have two burnt out bulbs..
Old Nov 15, 2002 | 09:15 AM
OscarCL3.2's Avatar
Go Gators
seems it would be easier to check the fuse first?
Old Nov 15, 2002 | 09:21 AM
DRM600's Avatar
that happened to me and i couldn't find a fuse for those lights. it turned out that both bulbs burned out. most likely that's what you have.
Old Nov 15, 2002 | 10:35 AM
beestea's Avatar
Mine both burnt out... one at a time tho. I didn't really care because they don't make much light anyhow. When I took my car to the dealer to get the free virginia inspection they replaced both for free and I didn't even ask them to.
Old Nov 15, 2002 | 01:23 PM
Happy CL-S Pilot
Thanks for the replies ...I will stick in the stock one and see if they do work... then I will buy e pairs of PIAA.... but damn it.. I did not know I was burning Driving lights...
Old Nov 15, 2002 | 05:54 PM
danny25's Avatar
I just upgraded to the PIAA 19224s cause one of my bulbs burned out so I figured it was a good time to change both. It look soooo much better now, no more orange yellow halogens.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
HeloDown
Sep 8, 2015 06:51 PM
