Bosch sparkplugs
I'm about to take my 01 CL-S in for its 22500 service......do you know if Bosch makes the +4's for the CL? Denso's website said those spark plugs were about 13 bucks each, that seems steep.
well the manual states that you dont have to replace the spark plugs until 100k miles
but i dont think it will hurt to change them out
i have not used the bosch but i heard they work well
but dont expect any big gains
sidemarker
sidemarker
sidemarker
sidemarker
S/C'd Accord Coming Soon!
Avoid long life platinum plugs like the plague.
The reason they last long is because you are probably giving up performance. There is normally a trade off.
If you don't mind changing plugs every 30k miles I'd go with the NGK Copper plugs. I think they are called V-Power or something like that.
Copper is a better conductor than Platinum and 6 copper plugs will cost you less than two of the expensive stuff. Just make sure you get the right heat range.
Our cars already come with platinum plugs. That's the reason for the 100K change. The consumer report did a test on the 4-tip Bosch plugs and found no difference in performance and mileage compared with their regular platinum.
Here's a good point that I pulled from another board: The extra metal at the tip makes them more prone to detonation than a standard plug.
I'd recommend standard platinum plugs, but not Bosch's. I used to buy Boschs for my old car, and the last time they were changed out, there was 3 out of 8 plugs where the platinum plug was gone! NGK makes a great platinum plug, which is used by pretty much all the auto makers.
Oh yeh, electricity flows to the shortest path, so don't be fooled into believing a V groove, or those Splitfires actually give 2 hot sparks. It's just going to spark from the path of least resistance.....
1st - Why change the ones you have now? I don't think you will see a noticeable diference, either way, if you change the plugs.
When I change my plugs, I always go to the regular Bosch Platinums. I have never noticed a difference either way. Maybe a slight better performance, but only because the old ones had about 75,000 miles on them.
juice
juice
juice
juice
You're right though, it's a waste of time to pull out the stock plugs.
Originally posted by ScubaCL-S
Are the spark plugs in the type S and regular CL the same?
AS mentioned above the CL and CLS have a different heat range. The higher compression alone can account for this.
IMO, stick with the stock plugs (unless you have some compelling reasons to change)
The CLS and CL 2001-2003 have a very high energy, fast rise time coil/module sitting right on top of every plug. The general rule is: the weaker the stock engine's ignition system is and the more power you try and run through it (turbo, S/C, mods, etc), the more a plug, wires, multi-spark (MSD) ignitions can help.
People forget is that a car is not always sitting at WOT on a dyno (those graphs for the some of those plugs look like free HP -- hey? ) Unfortunately, you don't always get that gain in a well maintained engine with a good ignition system (our car) and very few people give a second thought to subtle changes in:
Emissions
Part load performance
Longevity
Subtle combustion changes (that are not always for the best)
Heat range issues that only show up intermittently (fuzzy end stuff that makes for a pain in the ass problem).
And the piece of mind that comes from not having one more mod for some knuckle-dragging tech to blame for an engine problem.
IMO, "If It ain't broke--don't fix it" applies to our plugs (stock or with I/H/E/P etc) (notice I left out the S/C...)
Emissions
Longevity
