View Poll Results: IMRC Status for FI CL's
Connected and functional
50.00%
DISconnected, stays closed.
50.00%
Voters: 12. You may not vote on this poll
Boosted CL's please answer
Old Feb 16, 2005 | 07:22 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
For those of you who are Forcing Induction, what is the status of your IMRC? Personally I still have mine connected but am thinking about disconnecting it in lieu of the recent posts...
Old Feb 16, 2005 | 07:53 PM
Seattle Cl-S's Avatar
Blown LS6!!
I get pinging 50% of the time at WOT with the thing connected. I like my motor
Old Feb 16, 2005 | 09:15 PM
mrsteve's Avatar
Disconnected.
Old Feb 16, 2005 | 09:24 PM
Chemmech's Avatar
Removed
Old Feb 16, 2005 | 09:25 PM
mrsteve's Avatar
Originally Posted by Chemmech
Removed
LOL... I saw that you posted and I was like, "wait, where's the poll option for I don't have one anymore" LOL
Soon to be in the "removed" club.
Old Feb 16, 2005 | 11:08 PM
power3dfx's Avatar
Parting out 02 Type S :(
i keep mine connected, since i feel no problems that way. even before emanage, i would get detonation every now and then but that was it.
Old Feb 16, 2005 | 11:13 PM
mclarenf3387's Avatar
So the only difference between you boosted CL-S' and us CL-P's TB wise is the bore...
How come the IMRC causes knock with boost?
Old Feb 16, 2005 | 11:19 PM
Smitty's Avatar
disconnected.. removed soon enough
Old Feb 16, 2005 | 11:21 PM
mrsteve's Avatar
Every now and then is one too many times to hear detonation for me!
Old Feb 16, 2005 | 11:37 PM
allmotor_2000's Avatar
Hmm.... never tried it disconnected, maybe I should
If it reduces detonation, maybe I can advance my timing and get more power!
Old Feb 16, 2005 | 11:56 PM
Okay... I just went and tried it out both ways. It's significantly quicker with the IMRC connected and functional. It rips the tires loose in 2nd with it connected. With it disconnected, it just sorta revs up.
I do hear the occasional *ping* at the VTEC changeover once in a way... but I have retarded a LOT of timing.
Old Feb 17, 2005 | 12:06 AM
sgmotoring's Avatar
Bleed Honda Blue
Don't have one anymore! :wink:
Old Feb 17, 2005 | 12:32 AM
BlueCLS6's Avatar
ex 6 Speed owner :(
LOL I love how you always go and test everything out! A true enthusiast
Old Feb 17, 2005 | 01:41 AM
power3dfx's Avatar
I concur with allmotor's findings. However, i conducted my test when my FP wasnt right, but i still felt a difference. Im gonna disconnect it again since the car is running well, but i think there will be a power loss.
Finally, when i dyno, i might just disconnect it for one of the runs to see if it does make a difference. I will post on that when it happens in a few weeks.
Old Feb 17, 2005 | 03:13 PM
dfv3.2CL-S's Avatar
Sorry for the stupid question, but what is the IMRC in simple terms.
Old Feb 17, 2005 | 08:47 PM
Allout's Avatar
Blown is Best
Connected but I'm only running standard SC boost.
Old Feb 17, 2005 | 08:49 PM
mrsteve's Avatar
I would explain but it's nothing that hasnt' been covered 800 times already on both the CL and TL forum. Try a search.
Old Feb 18, 2005 | 12:13 AM
flint's Avatar
I ran mine at the track several times with it connected and disconnected. It was about 1-2 tenths quicker connected. Mine is staying connected. I do get some light pinging. Seems worse when it gets colder outside.
Old Feb 18, 2005 | 03:49 AM
SCTL-SS's Avatar
13.68 @ 102.56
Put me down for:
Old Feb 18, 2005 | 07:24 PM
scalbert's Avatar
I had mine disconnected since early on.
Ramanan, I think I know why you are seeing such a difference. Both Brad's and my dyno tests showed little difference. But then again, that was just with the FPR adding fuel. It could potentially be that yours is tuned well enough using the E-Manage that there is no benefit as you can get the extra fuel where it is needed. With it connected with just the FPR being used, it would lean out just after the VTEC change over; a non-issue for you.
So IMO, without the E-Manage it shoudl help. But with the E-Manage you can tune out the lean condition.
Just FYI, below is Brad's dyno showing the differences. Although there were some it wasn't enough to keep having knock.
Old Feb 18, 2005 | 07:31 PM
Possibly true. I have my E-manage tuned to give a stable A/F at all times under boost. In fact I start richening things up just before boost (to eliminate the 'turn-on' boost condition you probably know about).
However, why would the car lean out before the VTEC changeover with the IMRC connected? I know that the car adds a LOT of fuel as it transitions into VTEC, but how does keeping the IMRC closed prevent the car from leaning out before VTEC? One answer is that less air requires less fuel. That also means that you would lose power before the VTEC changeover!?!
Old Feb 18, 2005 | 07:36 PM
scalbert's Avatar
It doesn't lean out before the change over; it does just after at about 5000 RPM.
Correct, there was less air going in with it disconnected and less potential power. But with it going lean and knock occuring the ECU was killing timing negating the potential power increase. Disconnecting it limited the air input potential; hence greater boost numbers with the SC, but it stayed at a reasonable A/F ratio and no ECU timing killing knock.
Old Feb 19, 2005 | 12:10 AM
poisx7's Avatar
FI'
great debate good info by people who know what they doing.
spread the knowledege.
Good work
Eggs999bacon
Sep 24, 2015 10:08 AM
NBP_BALLER
Sep 23, 2015 08:18 PM
Sep 17, 2015 08:57 PM
Koff
Sep 9, 2015 02:55 PM
