Boost on the way !!!!
fastest time 13.4@107 !!!
Well the type R is getting a jackson racing supercharger.. I couldn't pass this deal up i got it dirt cheap.. My plan is to run the 8.5PSI on the stock motor for alittle while, then build the motor for 12PSI and some spray...
318whp/289wtq @ 6psi
Cool, I had a Type R back in the day but never had a chance to boost it. Good luck. Why didn't you go with the turbo? More power potential I think.
turbo's are much better but also cost between 4-5k... i got this supercharger kit for just over 1k
I actually had the jackson racing supercharger w/high boost pulley with nitrous on my B16 del sol. Make sure you have enough fuel dude, I ran very lean and it kept knocking so be very careful. But your it will be fast, first gear will be so fast you wont even use it.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Location: a place that I look forward to move away from
Originally Posted by fastvtecCL
Well the type R is getting a jackson racing supercharger.. I couldn't pass this deal up i got it dirt cheap.. My plan is to run the 8.5PSI on the stock motor for alittle while, then build the motor for 12PSI and some spray... ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
thanks!
Originally Posted by peakpowermotoring
I actually had the jackson racing supercharger w/high boost pulley with nitrous on my B16 del sol. Make sure you have enough fuel dude, I ran very lean and it kept knocking so be very careful. But your it will be fast, first gear will be so fast you wont even use it. ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
i also ordered my RC 550cc injectors today along with a walboro 255 intank fuel pump... i think that should enough
Does the jrsc comes with some type of engine management? ....i did get lucky and boost the TL finally even though I never boosted the Type R I had.
Does the jrsc comes with some type of engine management? ....i did get lucky and boost the TL finally even though I never boosted the Type R I had. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
i'm going with RC 550cc injectors with crome chipped ecu for boost (9200 rev limit) mugen exhaust with no cat.... (8.5 psi)
11psi on order
the guy i bought the kit from made at 8.5 psi on 440cc injectors and greddy e-manage, 2.5 inch exhaust, no cat
he put down 255whp//195wtq at 8700 rpm
BoricuaTL
04-08-2016 01:08 PM
NBP_BALLER
09-23-2015 08:18 PM
09-14-2015 10:48 AM
