Block Safe Tempature?
Old May 10, 2001 | 06:23 PM
Aysle's Avatar
What is the melting tempature of our block? What would be a safe tempature to keep it under? Where would be a good place to mount a tempature sensor?
01 CL-S Navi - Black/Ebony
Xephyr CAI with I get my Car back
Alpine MRV-1507 V12 Amp - Tested @ 1,237 Watts RMS - 2,078 Watts Max
2x Alpine 12" Type R - Custom Enclosure
Escort Passport 8500
[This message has been edited by Aysle (edited 05-10-2001).]
Old May 10, 2001 | 07:04 PM
scalbert's Avatar
Aluminum melts at about 1600 F. Short burst of power can have the EGTs go over 1600 F in some turbo applications, not our NA cars. But with nitrous the same high temps can be acheived. In most cases though, try and keep the EGTs below 1500 F.
As for block temps, that would depend on the location measured. But you could look at the coolant temp, normally around 200 F. If your coolant starts going well north of 225 F the PCM will pitch a fit and you should start getting worried about over heating.
Old May 10, 2001 | 09:13 PM
Aysle's Avatar
Im going to run NOS, so is there something I can get the temp from other than the coolant, that way there is not time delay in temp raise?
Old May 11, 2001 | 11:01 AM
scalbert's Avatar
The best thing to watch is the EGT (Exhaust Gas Temperature). It really is the best indication as to the combustion status at a reasonable price.
All it involve sis a TC (thermocouple, normally Type K) mounted in the exhaust manifold near the ports. Then the TC wire fed to a gauge in the car. This will display the EGTs in C or F.
During cruise most EGTs hover around 900 - 1000 F and jump to the 1400 range during WOT. They can continue to climb even further if you stay on it.
Its not a bad idea to watch this when running NOS. Of course in most cases where damage did occur to the engine due to lack of fuel the EGT probably wouldn't of reacted quick enough. But it does give an indication to the health of the system. Plus it does allow you to tune the system a bit better. At WOT; cooler EGTs indicate a richer condition than with higher temps. If you start hitting 1600 F you are too lean and time to get more fuel flowing or back off on the nitrous.
Hope this helps.
Old May 11, 2001 | 03:33 PM
Aysle's Avatar
<font face="Verdana, Arial" size="2">Originally posted by scalbert:
[/B]</font>
You wouldn't happen to know where I can find one? I found some thermocouplers but can't seem to find gauges to attach to them
Old May 11, 2001 | 05:00 PM
scalbert's Avatar
Check out Summit Racing or Jegs:
http://www.summitracing.com
http://www.jegs.com
Both will have the probes and gauges. This will require tapping into the exhaust manifold...
MilanoRedDashR
Oct 2, 2015 10:49 AM
merc009
Sep 29, 2015 03:06 PM
07Acuradude
Sep 29, 2015 03:01 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
4drviper
Sep 23, 2015 07:42 PM
