Block heater
Old Dec 15, 2016 | 08:19 AM
mattcl-s's Avatar
Block heater
Hey everyone so its -15F here in Minnesota and its only going to get colder. I am wondering where on the block the plug is for the block heater and if it hard to get to? car is not like this cold of starts in the morning I had one on my old car 2000 ford contour and it worked great in temps like these. let me know guy thanks
Old Dec 15, 2016 | 09:03 AM
mattcl-s's Avatar
I searched on google and came up with nothing
Old Dec 15, 2016 | 09:31 AM
gnuts's Avatar
3.5 psi
I think it replaces the coolant drain plug. info is hard to find on this.
Old Dec 15, 2016 | 09:33 AM
mattcl-s's Avatar
I am having a tough time too just trying to find out where its located on the block
Old Dec 15, 2016 | 10:56 AM
mattcl-s's Avatar
I guess its called a "freeze plug" not drain plug
Old Dec 15, 2016 | 05:08 PM
teh CL's Avatar
I've been thinking about the same thing as it's getting pretty brisk around here & the car sits outside all night
Old Dec 15, 2016 | 05:13 PM
teh CL's Avatar
Did some searching & there's no oem option for the CL..
Found the install for a 04+ TL though.. ​​​​​​​https://www.acurapartswarehouse.com/...ock-heater.pdf
Old Dec 15, 2016 | 11:20 PM
Tosh's Avatar
Eurotrash
Do they still offer those generic oil pan heaters? They're flat and you attach them to the underside of the pan, so a bit less invasive than a freeze plug heater.
Old Dec 16, 2016 | 01:53 AM
rp_guy's Avatar
'03 ABP YA4-S 6MT
08T44-S5B-100 generic honda block heater. follow the instructions for the TL. canadian cars already have one installed. was on my j32a2 and now j35a3
if you're worried about it cranking get a battery warmer. if you want it to start slightly easier use a block heater.. otherwise an oil pan heater is best for the engine since it's heating the oil and not just the coolant.
Old Dec 16, 2016 | 10:41 AM
mattcl-s's Avatar
called the dealership and the part is discontinued
Old Dec 16, 2016 | 10:43 AM
mattcl-s's Avatar
I am not sure if they have those for the cl ill have to check. I did find the block heater from advance auto parts its about 35$ and have to special order it not too bad
Old Dec 16, 2016 | 10:45 AM
mattcl-s's Avatar
main reason is just so it starts easier I found block heater works pretty well In my previous car since its about to drop to -23f here this weekend I wanna have her plugged in
Old Dec 16, 2016 | 10:48 AM
mattcl-s's Avatar
I can only imagine, this damn polar vortex sucks!!! mine sits all night outside too poor thing
Old Dec 16, 2016 | 10:57 AM
mattcl-s's Avatar
so this should be pretty much the same for the cl right?
Old Dec 20, 2016 | 11:07 AM
TheWeez's Avatar
I Wanna Beer
I've had my CL-S6 in Minnesota for 6+ years and haven't had issues with starting even when it's crazy cold. Worst was leaving it at the airport for a week and coming back to it after it sat outside in -20º a couple years back. Started right up but the power steering was frozen. Even after idling for over 30 minutes it was frozen. Drove home having to strong-arm the steering but after it sat in the garage overnight it was fine again.
The engine block heater for the CL is 08T44-ST7-200 but it's been discontinued.
Old Dec 20, 2016 | 11:19 AM
like the fluid was frozen? damn that can't be good for your PS system Was it really old or something? It's also hygroscopic like brake fluid so maybe just needs a new flush.
Old Dec 20, 2016 | 11:22 AM
TheWeez's Avatar
I Wanna Beer
Fluid wasn't old and everything checked out fine. Shop said it's common when left outside for a few days in the -20º continuously. It may have hit those temps here on Sunday but only for a couple hours. Not day after day like it did a couple years ago which is what froze things up.
Old Dec 20, 2016 | 11:52 AM
mattcl-s's Avatar
mine started right up Sunday morning but it was not happy. I ordered one should be here soon then going to take it to a shop to install
