Biggest throttle body on j32a2 manifold
Old 02-26-2018 | 09:53 AM
toyotawild's Avatar
5th Gear
What size blox should i put on my PnP stock manifold. I read some say 72 also read 74. Im not against doing a spacer either. I can port match myself.
What other t body options are there. I don't think the max bore is worth the money.
thanks guys
Old 02-26-2018 | 02:26 PM
cls6life's Avatar
I am also curious to know this information. I am planning on boring out the OEM TB to the largest size; anyone know what that is? Thank you!
Old 02-26-2018 | 09:10 PM
gnuts's Avatar
3.5 psi
I've seen a few use the Blox 74mm TB. I think you need to find a way to get vacuum before and after the blade. Not a lot of info on it.
Old 03-01-2018 | 12:30 PM
TheWeez's Avatar
I Wanna Beer
Seems a waste if you're not FI.
Old 03-08-2018 | 10:13 AM
cls6life's Avatar
What is the biggest size you can bore the OEM TB?
01CLinprocess
01-14-2017 04:00 PM
DEPTLS
12-19-2010 05:55 PM
akertulis
11-16-2010 11:33 PM
reese8789
07-07-2010 12:43 AM
Excelerate
12-06-2008 08:41 AM
Quick Reply: Biggest throttle body on j32a2 manifold
