big brake system
Old Jan 31, 2005 | 05:54 PM
djinferno's Avatar
big brake system
http://www.autocarparts.com/part/1235/1
Has anyone tried these or anything else you would suggest?
Old Jan 31, 2005 | 05:59 PM
NSX-Tuner's Avatar
boosted is best
Check with Allout and Red Rider... they both have Rotora BBKs...
Old Jan 31, 2005 | 06:00 PM
Rollin'... White 2 seater
brakes
I think that is really the only brake kit that anyone else on this board uses. I didnt know they cost 1300 but from what everyone says they are worth it. Ilke the carolina blue ones, if you have a complementing color run with those b/c everyone has the red joints. OH yeah doa search of the pictures or whateva and you will see someone with those on thurr.
Old Jan 31, 2005 | 06:11 PM
NSX-Tuner's Avatar
boosted is best
Originally Posted by bdubfosho
I think that is really the only brake kit that anyone else on this board uses...
Not true... I've got the Brembo BBK that CompTech sells. It's almost twice the cost, but a better design and quality - IMO. Don't get me wrong, the Rotora BBK seems to be of good quality.
Old Jan 31, 2005 | 06:34 PM
djinferno's Avatar
then my secong question would be is it worth the extra 1500$ for brembo
Old Jan 31, 2005 | 06:58 PM
NSX-Tuner's Avatar
boosted is best
IMO - Absolutely!!! I paid $2689 installed.
  • Brembos have a floating hat on the rotors that help center rotors, provide better cooling & isolation and minimize wear
  • Cross-drilled rotors run cooler than slotted
  • Both the calipers and rotors are much lighter than OEM. Not sure how much lighter they are over Rotoras
Old Jan 31, 2005 | 07:01 PM
djinferno's Avatar
anybody else?
Old Jan 31, 2005 | 07:46 PM
rondog's Avatar
Former Sponsor
No more warped rotors, and stops like a champ. wheels cleared the BBK too without spacers. (test fitted the 18" too, in reference to nitequills setup, still fits without spacers)
Old Jan 31, 2005 | 07:51 PM
SCTL-SS's Avatar
13.68 @ 102.56
anybody else?
I'm really pleased with the my Rotora set up. They are great stoppers. Brembos might be the better setup but Rotoras are 1/2 the cost(almost). -and then some.
Old Jan 31, 2005 | 09:27 PM
NiteQwill's Avatar
Adventurist.
My car is the white CL-S pictured above by Ron. The BBK is by far the best investment I have made on this car (yes, that's even over the headers and suspension).
The stock braking IMO sucks on the CL.
Old Jan 31, 2005 | 09:49 PM
Excelerate's Avatar
Former Sponsor
DJinferno if you are interested in this Big Brake Kit, please PM me for pricing.
Josh
Excelerate LLC
Old Feb 1, 2005 | 12:31 AM
Allout's Avatar
Blown is Best
Great investment IMO. Rotora kit is reasonably priced and replacement rotors won't break the bank when you need to replace them. The one piece rotor is not as good of a design as a 2 piece with the floating hat. Like cls6sp03 pointed out, the Brembo kit is a superior design but more expensive. Just depends what you're looking for. I would imagine that the differences in the kits would become more of an issue on the track. Less mass in the Rotora rotors will mean less heat capacity. On the street, you probably won't see it.
I did a 0 to 80mph to 0 run with one of my friends to show him what the SC and Brakes could do. The look on his face was priceless.
Old Feb 1, 2005 | 05:02 AM
djinferno's Avatar
Do these clear the stock 17's? I wanna know that cause I might do that now and do the rims this summer...
Old Feb 1, 2005 | 07:42 AM
NSX-Tuner's Avatar
boosted is best
I don't believe that Rotoras calipers would clear the OEM rims. The Brembos definitely not.
Old Feb 2, 2005 | 12:20 AM
Allout's Avatar
Blown is Best
My Rotora kit fit behind the stock 03 CL-S wheels with the help of a 5mm spacer.
Old Feb 2, 2005 | 12:43 AM
NiteQwill's Avatar
Adventurist.
I too needed a 5mm spacer.
Old Feb 2, 2005 | 10:05 AM
rondog's Avatar
Former Sponsor
Dude, I test fitted the Servos on my car and they cleared, have you tried or did you just take the shop's word for it, granted it was like a mm clearance...
Old Feb 2, 2005 | 11:05 AM
Smitty's Avatar
stock 17 inch rims need a 5mm spacer... aftermarket 18's MIGHT need a 3mm spacer...
that is what I run on my set-up.
Old Feb 2, 2005 | 12:24 PM
Excelerate's Avatar
Former Sponsor
If anyone needs that spacer I bought it for a customer who bought the ROTORA BBK from me locally, but we didn't end up needing it. So if someone needs that H&R spcaer send me a PM b/c they're usually out of stock.
Josh
Excelerate LLC
Old Feb 2, 2005 | 05:24 PM
ccannizz11's Avatar
My Work is Done Here
Hold on, let me get this straight.....
You pay $1500 for just 2 calipers and 2 rotors + pads, lines, and brackets????
So if I want to do the front and back, it's gonna cost me $3000????
Damnit, I'm retarded I thought the BBK included the setup for all four wheels.....
Old Feb 2, 2005 | 05:38 PM
NSX-Tuner's Avatar
boosted is best
One NSX four wheel BBK costs $10,000...
Old Feb 2, 2005 | 07:45 PM
Habib's Avatar
I am able to get a set of Brembo BBK cheap but they are four lug and I need them 5-lug does anyone here know how hard it is or if it is even possible to make them 5 lug.
Old Feb 2, 2005 | 08:33 PM
jlspeed29's Avatar
adapters in this case i think ur limited
Old Feb 2, 2005 | 08:43 PM
JaredGMS's Avatar
Meat stick
won't work....the rotor won't be the correct one, and the caliper probably will not mount to the stock bracket since it is for another car...
Old Feb 2, 2005 | 08:48 PM
Habib's Avatar
it was made for the same car but w/ a 4cyl, I have the V6
I am pretty sure I can just swap the hats but don't know how much those will cost
mclarenf3387's Avatar
They BBK is only for the front wheels. A BBK on the rear wheels is fairly pointless as the front brakes do about 75% of the work. If there was one for the rear, it would be more looks than anything.
Old Feb 3, 2005 | 10:08 AM
ccannizz11's Avatar
I didn't realize the difference between front and rear braking was that much.... 75/25? Anyway.... doesn't it look a little too weird when you have drilled/slotted rotors with bright calipers on the front, with stock rotors and dusty calipers on the back? Or are there cheap solutions to this aesthetic trainwreck?
I'm a as far as this mod is concerned
Old Feb 3, 2005 | 10:16 AM
Chaptorial's Avatar
I too have the Rotora BBK kit for the front and i couldn't be happier. No problems after 3 months and these suck bit down hard on every stop. If you don't want to go the extra mile and get the Brembos, this is the kit to go with.
Running with the stock 17’s I also needed a set of 5mm Wheel Spacers.
Rotora mentioned that a BBK for the rear wheels is in the works. about its overall feasibility but it sure would look cool.
Old Feb 4, 2005 | 12:02 AM
Edddie's Avatar
Ron,
We mounted the wheels after the BBK install and found that the clearance too inadequate (~.5mm). We decided it was safer to use the spacers. Dustin doesn't mind the extra wide stance anyways.
Old Feb 4, 2005 | 07:07 AM
TampaBayCLS's Avatar
dj, it is not that much more. I have sent you PM
Old Feb 4, 2005 | 07:17 AM
djinferno's Avatar
i'll get back to you on that, still havent received my car from carmax, i guess that the 3rd gear grind was more serious then first expected...
Old Feb 4, 2005 | 12:41 PM
Habib's Avatar
If someone has a set they want to sell PM or email prices to igitpd@yahoo.com
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
Sep 14, 2015 10:10 AM
nuldabz
Sep 3, 2015 05:49 PM
