best tire size fer 18" rims?
I have 225/40/18 but 235/40/18 is actually closer to stock diameter if your wheel offset and suspension drop can handle it.
I’ll be going with 235 when I replace my rubber next year.
Shawn S
Shawn S
Homeless
Azenis ST115
High performance with quiet ride. Z-speed rated.
235/40ZR-18 REIN B
Reading the Tire Size
$133.00 each
Ziex ZE-512
All-season performance. W-speed rated.
235/40ZR-18 95W REIN
$130.00 each
NT 555 Extreme Performance
Make no mistake, this tire is built for performance
235/40ZR-18 91W
$135.00 each
P-Zero Nero M+S
With driving force and and enjoyment, this tire works harder and plays harder.
P235/40ZR-18 91W B
$153.00 each
Some of these have higher load rating than stock. Just afew I've been looking at...there are more expensive out there. These are from Discount Tire Direct & prices include shipping...
235/40ZR-18 REIN B
$133.00 each
Ziex ZE-512
$130.00 each
235/40ZR-18 91W
$135.00 each
P-Zero Nero M+S
P235/40ZR-18 91W B
$153.00 each
Originally posted by chris3240929
P-Zero Nero M+S
P235/40ZR-18 91W B
$153.00 each
P-Zero Nero M+S
P235/40ZR-18 91W B
$153.00 each
Smitty
funny the 245/40's have a lower load rating then the 235 howeve i think the 235's must have the re enforced side wall... BTW 245's 25.7 235's 25.4
235 gives you more WIDTH... "meat on the pavement", but you have to watch your set up so you don't rub..
Things such as: Offset.. 42 is the lowest.. 45-50 is common.
Width of rim... 7.5-8.0...
once you get your rim figured out that you want, then you can answer these questions easier..
I can say this.. if you run a 18X7.5, a 235 size tire will be wide.."sort of look ballonish/bulgy on the sidewalls.. let alone you might have fitment issues..
Do you have a drop.
But if you run a 18X8, then I say, go for the 235, but watch your load ratings... the whip is not light.... I hope you choose a good tire too, not some cheap POS.
Do you have a drop.
hahaha thanks, but i already have 18x7.5 rims and right now i'm running on 215/40/18 tires... and they perfectly wrap the rim, but im lookin fer a lil more rubber, a lil wider i guess so im guessing 225/40 is ideal fer me
and smitty, yes my car is lowered
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
