Battery change? engine stall?
Old Aug 17, 2008 | 08:00 PM
jctzin's Avatar
Do you guys use any particular battery for your car? My car seems to stall a bit but it doesnt shut down, when I go below 2000 rpm I think is the battery because I charge it couple of times and it is not working. Every time I charge it when I turn my engine off after driving it for a good half an hour it would not start again even the alarm is not working. What do you guys think?
Old Aug 17, 2008 | 08:22 PM
FFEMTSHAFER's Avatar
Combat Medic
If your charging the battery and its not holding the charge then it might be your alternator. Try putting a volt meter on the battery with and without the car running. Should be around 13.5 - 14 volts while running and 12 - 13 with the engine off. Then again your battery could have gone bad and just wont hold a charge. Alot of people like the yellow top optima battery.
Old Aug 17, 2008 | 08:50 PM
fuzzy02CLS's Avatar
I vote your battery and or cables.
If the car stalls or wants to stall at low rpm your IAC valve could need to be cleaned or replaced.
I think these are separate problems your having.
Old Aug 17, 2008 | 10:45 PM
VIPCLS's Avatar
P.
battery
Old Aug 18, 2008 | 04:48 PM
jctzin's Avatar
thanks I will see if it is the battery first before I try other things...
Old Aug 18, 2008 | 04:54 PM
StypeCL02's Avatar
Dude I just changed Mine today and im haveing the same Exact problem it wants to stall out it did once.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Aleax
Sep 11, 2015 11:31 AM
HeloDown
Sep 8, 2015 06:51 PM
