bass cutting out
Old 05-22-2003 | 09:28 PM
nokio's Avatar
bass cutting out
i got my tranny changed and when i got the car back, my subs only hit at idle or at certain points in acceleration and not when braking......
the amp is fully connected and workin fine, but i dunno what could be wrong?!?!
help!
Old 05-22-2003 | 10:22 PM
AcurajL's Avatar
I hand out swivel heads
when you are braking you are increasing the necessary voltage in the car to rise, so if bass and brakes are on there is more voltage required. Sounds like a bad connection to the battery from the alternator OR a battery about to go bad OR if you have a second battery than definately that is going bad? Give me some more info so I can trouble shoot the scenario....
Old 05-22-2003 | 10:58 PM
MiK3Y's Avatar
that makes no sense. there is around 14.4v running throughout the car whether the brakes are applied or not.
sounds like a wire is loose somewhere and is intermittently making contact.....power wire or speaker wire. or maybe even RCA's.
Old 05-22-2003 | 11:14 PM
nokio's Avatar
not anything to the amp or any power from the batt
also it hits half as hard as before
Old 05-22-2003 | 11:30 PM
DDT-TypeS's Avatar
6SPDCLS
probably a grounding problem...make sure you have a good solid ground point...if your shit is in the trunk, find a good spot (where the tailights ground (driver side REAR behind plastic panel/driver side tail light area) is a good place to ground...make sure you don't ground on the fuel tank dust cover..I did once and it blew my amp (after 2 days of bumping it..one day, it just didn't turn on anymore)
Old 05-22-2003 | 11:41 PM
AcurajL's Avatar
Actually it does make sense because I had the same exact problem in my civic 6 months ago. Perfect bass while driving, even in idle, however when I pressed the brakes the music would come to a complete stop. We checked everything and what ended up being the problem was the alternator was unable to charge the battery to the full 14 volts and the power was dwindling. At brake the alternator isnt charging and yet you are slightly requiring more volts from the source. When the source has nothing left, the rest of the system wont work! So tada it does make sense
Old 05-23-2003 | 12:12 AM
nokio's Avatar
wtf, they fucked my alternator now?
it worked perfectly before?
Old 05-23-2003 | 12:13 AM
allmotor_2000's Avatar
I think you need to bitch-slap your alternator!!
Old 05-23-2003 | 01:28 AM
nokio's Avatar
lol ya know, i just need to bitch slap u!
jk i still love you
Old 05-23-2003 | 11:12 AM
biaaaatchh!!
Old 05-23-2003 | 02:34 PM
cmark's Avatar
how about getting a capicitor?
Old 05-23-2003 | 08:27 PM
nokio's Avatar
not the cap,
IT WORKED BEFORE THEY SWITCHED MY TRANNY
Old 05-24-2003 | 07:07 AM
Loseit's Avatar
Changin bulbs since '73
maybe the forgot to reconnect the wire that goes from the tranny to you alternator to your capacitor. It is an easy think to forget. Mabe the new ECU they put in puts less juice in your electircal system because they found that it puts to much of a load on the clutch packs causing premature failure. maybe....
mlody
12-04-2019 03:11 PM
Timmy18
10-17-2015 04:58 PM
kb1rl
09-30-2015 11:17 AM
CWOVette
1/2G MDX (2001-2013)
09-27-2015 03:29 AM
polish_pat
09-25-2015 01:24 PM
