Bad ground? Need help.
Old Mar 4, 2004 | 03:36 PM
raymas's Avatar
My 2001 cl type-s has an issue. last night the odometer section and sport shift gear indicator went dark. this morning, it came back to life, but only for a few miles then went dark. any ideas? I'm a long way away from a dealer, and was hoping someone has run into this before. As a newbie, i posted in the a/v electronics section but no replies yet. thought i would try here.
thanks in advance
ray
western mass
2001 type S
san marino red/ebony
Old Mar 4, 2004 | 03:42 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
get a hyper grounding kit
Old Mar 4, 2004 | 03:44 PM
civic4982's Avatar
ok, no but in all seriousness, you're not blowing any fuses so that knocks out the possibility of frayed wires that are grounding. electrical problems are a pain in the butt. if it were me, I'd take it to someone around your area that you can trust to look ati t and not charge you an arm and a leg. there's so many possibilities to where your issues may be on a problem like this.
Old Mar 4, 2004 | 03:48 PM
ChadT's Avatar
Spectacular Aroma About
I can take a look in the service manual later and see if those things share a common ground. I had a similar problem with my old Prelude. I tracked it right to a ground I had used to install a CD changer but forgot to tighten. Have you had anything installed on the car recently?
Old Mar 4, 2004 | 06:32 PM
raymas's Avatar
no odometer
havent had anything done to the car. I just bought it recently. no other electrical issues that i can tell so far, just those 2 things. i'd appreciate you looking in your manual!
thanks
ray
Old Mar 4, 2004 | 10:00 PM
ChadT's Avatar
Re: no odometer
thanks
ray
OK the gear indicator light and the LCD light for the odometer both go to ground G501. It's behind the console in the middle of the dash. Looks like it might be a bitch to get to. THere are a bunch of grounds that attach there to the same bolt. I can scan the diagram if you want to try and get to it.
Old Mar 5, 2004 | 03:22 AM
raymas's Avatar
if you wouldnt mind scanning the diagram I'd like to try to find it. Thank you very much!
ray
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
dirleton
Sep 25, 2015 12:25 AM
