Bad ground? Need help.
My 2001 cl type-s has an issue. last night the odometer section and sport shift gear indicator went dark. this morning, it came back to life, but only for a few miles then went dark. any ideas? I'm a long way away from a dealer, and was hoping someone has run into this before. As a newbie, i posted in the a/v electronics section but no replies yet. thought i would try here.
thanks in advance
ray
western mass
2001 type S
san marino red/ebony
thanks in advance
ray
western mass
2001 type S
SHIFT_over.so.I.can.see
ok, no but in all seriousness, you're not blowing any fuses so that knocks out the possibility of frayed wires that are grounding. electrical problems are a pain in the butt. if it were me, I'd take it to someone around your area that you can trust to look ati t and not charge you an arm and a leg. there's so many possibilities to where your issues may be on a problem like this.
Spectacular Aroma About
I can take a look in the service manual later and see if those things share a common ground. I had a similar problem with my old Prelude. I tracked it right to a ground I had used to install a CD changer but forgot to tighten. Have you had anything installed on the car recently?
no odometer
havent had anything done to the car. I just bought it recently. no other electrical issues that i can tell so far, just those 2 things. i'd appreciate you looking in your manual!
thanks
ray
thanks
ray
Re: no odometer
thanks
ray
thanks
ray
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
