B-pipe has arrived
Blown LS6!!
B-pipe has arrived
The Comptech B-Pipe was waiting on my doorstep when I got home last night. Impressive quality welds/bends. Anyway, hope to install it Saturday morning. I doubt I'll notice gains with the butt-dyno but I hope it drops me a tenth in the quarter this spring. We'll see. Anything I should know before install? It looks like a pretty easy bolt-on.
I got the b-pipe installed before the S/C was installed. I immediately noticed how much more drive-able the car felt after the b-pipe was installed; engine rev'd smoother and quicker. I would expect you to feel a definite improvement with the S/C. You should also notice a different exhaust sound too. And yes, you can expect about 3-4 for N/A applications and about 5-8 for F/I.
Congrats and enjoy...
2010 SHAWD
Originally Posted by sonnyboyacura
Would I notice these improvements if I installed this on my stock CLS?
Originally Posted by VeeralS05
Does the B-Pipe make the car sound more like a G35, a ricey civic, or a Mustang GT?
Blown LS6!!
I'm installing it Saturday morning in my friend's garage. I'll let you know the change in sound. I have Thermal exhausts currently on the car...so it already sounds a little bit throaty.
Blown is Best
Don't forget to use some solvent to wipe it down before you start it up. I used Brake Clean to remove residue.
Keep an eye on the boost. I'm curious if there's any affect.
El Presidente
Definitely not ricey nor a stang GT. Has a unique sound of it's own that is much more aggressive sounding than stock, but not too loud.
the whole setup sounds hypnotic! oh man did we have fun on the twisties
Blown LS6!!
Is this so the stainless doesn't discolor?
Affirmative. Fingerprints, grime, bugs, plastic, a piece of plastic ...all will tend to become one with the pipe once you start the vehicle and it heats up....although it seems a bit futile when one considers that it will just get dirty again when you actually drive on any sort of pavement including, but not limited to asphalt, gravel, concrete, dirt, grass, etc. and so forth and so on.
Oh and also, stainless steel components are sometimes coated with an oil type residue before they are shipped which, when burned, leaves a dreadful stench.
No idea, but wouldn't that be a waiste?
Nope. The stock mufflers flow pretty damn well IMO. I noticed ZERO gain in performance from just the Comptech mufflers. The Comptech B-pipe + stock mufflers would probably net you about 5whp.
Beware of leakage
Blown LS6!!
B-pipe went on this morning. Took almost 2 hours because one of the three bolts connecting the center pipe to the cat was stripped while removing it. I had to go to an Acura dealer to get a new one. $13 for a damn bolt. Can you believe that? Anyway, the sound is awesome. My friend drove it while I stood outside and it sounds very aggressive. It drones a little in the low rpm's, but disappears soon after. The Thermal exhausts might be adding to that droning. As far as additional pulling power, can't feel it. We'll just have to wait for the track I guess.
Subie Dubie
Every little bit helps. I'll be interested to see if it brings your quarter down any.
As for the droning... it's probably from the b-pipe cause I noticed that same thing after installing it. You'll also notice the droning going up hills.
After driving it around for a while, you should notice the improved drivability; smoother and quicker reving.
Blown LS6!!
Originally Posted by darrinb
is it louder than before??
It is a bit louder than before. Much deeper tone overall. I kinda like it but my wife isn't really a fan.
The car does seem to rev a little easier. Could just be wishful thinking though.
Beware of leakage
Droning is probably from the thermals, I remember how they sounded on my car, and I can only imagine what it would be like with the B pipe. I bet is sounds really deep.
As for the reving a little easier, that's not your imagination. I noticed the same thing after installing it. I would say though, smooth reving was the most noticeable thing after the change in sound.
Liquid Ice
You could have also tried Home Depot / Lowes for the bolts, not the exact same thing as the ones for the exhaust, but they'd fit and it'd be a hell of a lot cheaper
Blown LS6!!
Originally Posted by LiQiCE
Damn! Thats highway robbery. I think when I called around to get some bolts for the S2000 (same exact bolts) ... some of the dealers quoted be like $10-15 a bolt... If you buy the bolts online its like $8 each ... And even that is too expensive! Of course, if you're desperate and you need it that day, then online isn't a good option.
I just wanted to make sure I got the right bolts so they wouldn't back out over time.
And I personally think Lowes > Home Depot for most DIY supplies. Lumber is straighter, better choice of lighting fixtures, higher end toilets...
Blown LS6!!
Home Depot is our #1 client, so I'm biased. Home Depot Lowes
Don't get me wrong. I remodeled my entire kitchen myself and most of the supplies came from HD. I'm now on to the 2nd bathroom and, again, most of the supplies are coming from HD. BTW, got any 10% discount coupons? I use 'em all the time and I've saved tons by using them.
