Attn: Scalbert And/or Smitty And All Others W/ Mugen T-stat
Old 11-23-2003, 03:14 PM
  #41
scalbert's Avatar
There are three fan switches on the 5AT. However, the only one to care about for this is the one on the T-Stat housing.
Old 11-23-2003, 08:32 PM
  #42
bullaculla's Avatar
Originally posted by fuzzy02CLS
I see now. Where was I when this was discussed? Since it's hot in FL almost all year this may be good for me. Does all this just swap right in, or is there some wiring/moding involved?
would help me too! sounds like my next mod.
where was I during all this?
probably in ramblings
Old 11-24-2003, 06:54 PM
  #43
flint's Avatar
Is there a how-to in the archives?
Old 11-28-2003, 03:55 AM
  #44
fuzzy02CLS's Avatar
Ok I put my stuff on Thanksgiving morning. Took about 1.5 hours. It wasn't very hard, but It was a pain for me. I though it would be easier to take the fan switch off after I took the theromstat housing out, but the damn thing wouldn't come off. So I put it back in, took my open end wrench & it broke loose. Then had to take out the housing again. Next, I had a bitch of a time getting the stock thermostat out. It was stuck in there very good. Next I tried to fit the Mugen stat in, & the gasket was too big, I couldn't get the housing back on. So I just used the one off the stock T-stat. Is that ok to do?? I hope it was the correct t-stat. It had the same part # as posted. It fit fine. I used a bottle of water wetter as well, & added some more water to the system since I lost a bit of coolant in this process.
Old 11-28-2003, 07:21 AM
  #45
scalbert's Avatar
That is what you are supposed to do...
Old 11-28-2003, 07:42 AM
  #46
fuzzy02CLS's Avatar
Good
Old 11-28-2003, 08:11 AM
  #47
ModAddict's Avatar
Do I need to drain all the anti freeze to do this?
Old 11-28-2003, 08:30 AM
  #48
fuzzy02CLS's Avatar
I had too. There was still some in the t-stat housing on mine. I lost some.
Old 11-28-2003, 04:29 PM
  #49
scalbert's Avatar
No, I didn't. I just cleaned up afterwards...
Old 11-29-2003, 11:46 AM
  #50
ModAddict's Avatar
All done here also. It does seem as if the temp gauge is a notch lower. The heat gets plenty hot now at 40* outside. We'll see around Jan/Feb how well it heats up. I hate antifreeze,.... slimey crap. :shakehd:
Old 11-29-2003, 11:57 AM
  #51
ModAddict's Avatar
If I had any balls I would have bypassed the throttle body coolant lines also. Maybe when the TB goes out to be opened up.
Old 11-29-2003, 02:00 PM
  #52
Chemmech's Avatar
What's the purpose of coolant lines in the throttle body anyhow?
Old 11-29-2003, 03:06 PM
  #53
scalbert's Avatar
And it seems the smell last for day in your skin.
Old 11-29-2003, 03:07 PM
  #54
scalbert's Avatar
To help heat the air at idle for emission and warms the TB to prevent sticking due to frost.
Old 11-29-2003, 08:06 PM
  #55
ModAddict's Avatar
This mod might keep the trans cooler also. Engine coolant is used to warm up the trans fluid,....although it may head to the trans cooler after that. Hmm,...
F-C
Motorsports News
33
08-22-2018 09:53 AM
Jinkazetsukai
11-21-2015 05:28 PM
DerrickW
11-15-2015 05:52 PM
dirleton
20
10-16-2015 01:48 PM
0opie
09-22-2015 04:15 PM
Quick Reply: Attn: Scalbert And/or Smitty And All Others W/ Mugen T-stat
