Attempting timing belt change.
Old 03-29-2006, 08:04 AM
CLsuperhero's Avatar
A few questions...
1) I want to confirm that an 01 type S has a tensioner. (That's what I got from using the search button)
2) I'm going to replace the crank pulley with the UR one and wanted to make sure no other pullies were necessary.
3) Does the water pump absolutely need to be replaced as well or can I let it slide? If so how much does the water pump part generally cost?
Old 03-29-2006, 08:20 AM
I'm here in spirit...
Lord Helmet's Avatar
After helping ghost_master with his cams on the 3.0, doing the timing belt is more than likely going to be a PITA and now I know why it's so expensive.
The water pump can be had here http://www.acuraautomotiveparts.org/...prddisplay.jsp for $92.63.
I think the only pulley that will get you any gains is the crank pulley... or so I've read. I'll let someone else answer the other questions.
Old 03-29-2006, 12:29 PM
dgracer's Avatar
The rationale behind replacing the water pump is that you have to remove it, and if you are changing the timing belt, than you already have 100k on the pump which is when you can expect them to start failing, so you might as well replace it. The labor to change it on its own is pretty high so think about that.
Old 03-29-2006, 01:11 PM
ghost_masterCL's Avatar
yep definitely a pain in the ass to change teh timing belt. My hands have at least 30 little cuts on them from getting the damn timing belt covers off and other miscelaneious shit. good luck.
Old 03-29-2006, 03:40 PM
yeah it's definitely going to take nearly an entire day to do with the tools I have
vaughanml2
11-01-2021 10:16 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
09-16-2015 12:21 PM
merc009
09-14-2015 06:43 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Attempting timing belt change.
