Anyone know their Intake Air Temps ?
Membistered Regember
Howdy here is some tests i've run during the winter season (about a month or so ago)
Tools used: torquepro android market app
android phone
elm 327 bluetooth adapter
method: hook up elm 327 bluetooth adapter to service port to read check engine lights and monitor information from the ecu of the car by using an android phone with the torque pro app (probably will write a thread on this nifty device)
Before the bypass mod car warmed up, around 65 degrees or less outside
air intake temperature (idle): 130-140 degrees Farenheight
Air intake temperature (cruising): 110-120 degrees farenheight
air intake temperature (Wide open throttle): high 98-110 degrees farenheight
with the bypass mod: (same, warmed up, around 65 degrees or less outside)
air intake temperature (idle): 100-120 farenheight
Air intake temperature (cruising): 85-99 farenheight
air intake temperature (Wide open throttle): lowest recorded temperature 65-78
original thread
https://acurazine.com/forums/2g-cl-2001-2003-50/j32a2-throttle-body-coolant-bypass-cheap-%40%24%24-mods-873724/
Hope it helps take care nice 3.7!
android phone
original thread
The following 2 users liked this post by jaeravenal:
ANC297 (01-22-2013),
richardparker (01-20-2013)
rcs86
08-02-2016 06:52 PM
