Anyone in Houston reset their SRS light before?
3-piece FTW
I'm looking for some help on resetting the SRS light because I have tried and tried but I can't even get it to the first step using the paper clip method where the light does turn off then turn back on.
Maybe someone in Houston that has done this before can help me out because the dealership quoted me $45 dollars to check it out. Please PM me or respond, I would appreciate it
Thanks again..
Thanks again..
3-piece FTW
Originally posted by myasiathai
I did that. For my gf's CL. I go to UH. I might be free this weekend, especially Sunday. Let me know when u're free.
Duy
Duy
Retired. Not available.
It depends on the code, if it is a permanent code (i.e removing a fuse while the engine running), you cannot reset it with the paper clip. I tried it already.
1- look underneath dash, near fusebox, for a 2-wire yellow plug, disconnect it and pull it down so you can work with it.
2- turn ignition OFF
3- jumper the 2 wires together (cut paperclip in half and straighten, insert one end of both halves into back end of plug where each wire goes in, touch them together and hold)
4- turn ignition ON (SRS light will turn on for 6 seconds, then turn off)
5- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will turn back ON)
6- within 4 seconds of SRS light turning on, jumper the 2 wires (SRS light will turn back OFF)
7- within 4 seconds of SRS light turning off, unjumper the 2 wires (SRS light will blink ON and OFF, indicating SRS function is reset)
See ya SRS light...
When you're done don't forget to plug the connector back in.
See ya SRS light...
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
