Anyone have rubbing problems with 235/40/18 & Comptech drop ???
I’m currently running 225/40 and have never rubbed, but I’m looking to go 235/40 for my next set of rubber.
I rarely have passengers in the back seat, but I do load the trunk up to capacity when I go on driving vacations.
I’m getting conflicting info from several of the tire dealers I talked to.
Some are much more conservative then others and don’t recommend this size.
My wheels are 18”-7.5 wide with +48 Offset.
My calculator & “finger scale” say it will work, but I’m just looking for info from someone who’s running a similar setup.
Thanks,
Shawn S
Thanks,
Shawn S
i'm running 235/40/18s on 18x8 wheels with a +48 offset and comptech springs. i have encountered no rubbing whatsoever. i have loaded the car to capacity (trunk and rear seats with personal belongings) when i drive cross country and have not had one problem.
btw i have bridgestone re750s
1-2-3-4-5-6-speeeeeed!!!!
I also was debating this issue between 225 and 235, I decided that I didnt want to incur any potiential problem/rubbing on the wheels so I went with the 225/40zr18 yoko parada spec II's, no rubbing at all!! not worth the hassle for 1/2 to inch of more rubber!! good luck with your choice!
just my $0.02
just my $0.02
Originally posted by darrinb
what tires u lookin for shawn??
See this thread: http://www.acura-cl.com/forums/showt...hreadid=126930
should be good ...
Hey,
I have 18x7.5 +48 rims along with Pirelli 235/40/18 ... fit on Astroboy's TL-S with Zeals dropped as low as you can go. I've got the CT drop ... I have no worries about rubbing. You should have no problems rubbing.
- derrick
- derrick
BoricuaTL
04-08-2016 01:08 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
Skirmich
09-15-2015 06:41 PM
k6biv
09-10-2015 06:37 PM
