Anyone have the install instructions for the AVelectronics kit?
Who ya gonna call?
SO I am set to do the install today on the NAV-TV Conversion, when I realized the kit I bought off a user here, didn't have the printed instructions. Does anyone have a copy they can email or fax to me? If so, email me at jakaman007@yahoo.com
I do have the DIY instructions from Bui's website, but I just wanted to make sure I am not missing anything since this is my first time installing.
ALSO, does anyone think its worth using expensive RCA cables for this? I figure the video quality is limited by the converters signal, so having better cables would not make a difference.
Who ya gonna call?
Anyone out there that can help??
I tried the install last nite and am only getting a white screen when I switch over to the Avelectronics box. The only thing I didn't connect was the reverse cable, since I don't plan on using it. I grounded the handbrake cable.
I also noticed the green light is always on regardless of what I do with the remote. It would flicker on and off, but I think that is due to a loose connection, since I got it to stay on no that I pluged the connector in a certain way. (I'm actually not sure if the remote is even working since this thing isn't doing anything)
Any help would be appreciated, My car is totally gutted out right now!!!
COME AT ME BRO!
im guessing u have a dvd player for it... is it the plug and play model or the one u have to cut the wires. if its the plug and play all u should have to do is unplug the wire from the navi and plug it in the ave box. u might need a switch so u can switch back and forth from navi to the dvd player. post pics if you can of what u have that might help
Who ya gonna call?
Yes, I do have a DVD player connected and it is the plug and play model. And this unit does have the switch and I can switch from NAv to the tuner, but when I switch to the tuner, i get a white screen. The remote doesnt respond, so im not sure if the box is faulty, the remote isnt working, or i installed something wrong. I will play with it tonite and try to get pics if possible tomorrow
Registered User
i used to have the kit myself, there should be 3 or 4 wires that aren't plug and play
power, ground, e-brake, and reverse(camera)
mayke sure the remote and IR sensor are plugged in correctly since there are actually 2 spots where you can plug the IR sensor into which would case it not to work
cycdaniel
12-17-2019 10:58 AM
nuldabz
09-03-2015 05:49 PM
