Anyone has problems posting pics right now?
Old Feb 1, 2003 | 06:43 PM
kritikadeo's Avatar
Starving CLS Driver
Finally got my modded cls dynoed (Pics)
But cant post pics. It says that the maximum is one byte. Thats rideculous. Help please. Trying to post up my new dyno results that was done today.
Old Feb 1, 2003 | 06:44 PM
fbazakos's Avatar
on bin laden
email it to me and i'll host it ... fbazakos@cs.umn.edu
they are cutting badwidth usage of the site, and not allowing attachments on-site.
Old Feb 1, 2003 | 06:49 PM
kritikadeo's Avatar
Starving CLS Driver
just sent it. thank you.
Old Feb 1, 2003 | 06:53 PM
fbazakos's Avatar
on bin laden
Here is the link:
http://www-users.cs.umn.edu/~fbazakos/kritikadeo.jpg
Old Feb 1, 2003 | 06:59 PM
kritikadeo's Avatar
Starving CLS Driver
thanks
Thank you. Dont know how u did that but thanks. Well enjoy folks. I was pretty pleased with the results. I went with 3 other guys 1 with integra ls turbo, 1 with integra type r turbo and another with an integra type r header, exhaust and cai. Was a long yet fun day.
BTW the date is supposed to be 2/1/03. We got too carried away and forgot to change that.
Old Feb 1, 2003 | 07:53 PM
darrinb's Avatar
///M POWER
is that on 17's or the 18's
Old Feb 1, 2003 | 08:07 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I was like then found that it's STD and not SAE corrected.
But anyhow with OBX and CAI... it's amazing!...
Now.. can some once correct that to SAE... do you know the Temp and Humidity and AP.
Old Feb 1, 2003 | 08:16 PM
Happy CL-S Pilot
Your CAI + OBX headers are giving you mad boost of torque after 5krpms!
kritikadeo's Avatar
Starving CLS Driver
Temp was around 10 degrees celcius. And its on 18"
Old Feb 1, 2003 | 08:18 PM
kritikadeo's Avatar
Starving CLS Driver
Yeah, I love it. The sound and the pulls were amazing.
Old Feb 1, 2003 | 08:25 PM
Happy CL-S Pilot
Today at noon, in Philly... the weather was:
Time Temperature Dew Point Humidity Pressure Visibility Wind Speed Gust Speed Precipitation Events Conditions
11:13 35.60 °F / 2.0 °C 35.60 °F / 2.0 °C 100% 29.86 in / 1011.0 hPa 1.0 miles / 1.6 kilometers 13.8 mph / 22.2 km/h N/A N/A Mist
11:54 35.60 °F / 2.0 °C 35.60 °F / 2.0 °C 100% 29.80 in / 1009.0 hPa 1.2 miles / 2.0 kilometers 13.8 mph / 22.2 km/h N/A N/A Mist
12:23 35.60 °F / 2.0 °C 35.60 °F / 2.0 °C 100% 29.80 in / 1009.0 hPa 2.0 miles / 3.2 kilometers 10.4 mph / 16.7 km/h N/A N/A Mist
12:54 35.60 °F / 2.0 °C 35.60 °F / 2.0 °C 100% 29.80 in / 1009.0 hPa 2.5 miles / 4.0 kilometers 10.4 mph / 16.7 km/h N/A N/A Mist
Old Feb 1, 2003 | 08:36 PM
kritikadeo's Avatar
Starving CLS Driver
Thanks a lot for that info cause i sure did not have it on me.
Old Feb 1, 2003 | 08:51 PM
Happy CL-S Pilot
Using this amazing calculator:
http://wahiduddin.net/calc/calc_hp_dp.htm
For:
Air Temperature 35.60 degrees F
Altimeter Setting 29.80 inches Hg
Dew Point 35.60 degrees F
Altitude 0 feet
Your results are:
Relative Horsepower 106.4 %
Air Density 1.2747 kg/m3
Relative Air Density 104.1%
Density Altitude -1347 feet
Virtual Temperature 36.9 deg F
Actual Air Pressure 29.81 inches Hg
Actual Vapor Pressure 0.208 inches Hg
Relative Humidity 100%
Dyno Correction Factor 0.94
234.5 STD WHP * 0.94 = 220.43 SAE WHP
Old Feb 1, 2003 | 09:03 PM
kritikadeo's Avatar
Starving CLS Driver
Actually, the dyno was done in atglen, PA about 56 miles away from philly. Well i downloaded a program that they told me to download in order to view the files that they saved from the runs onto my disc. I installed the program and did a SAE conversion via using that program and got a horsepower of 229.18. Program is called Dynojet runviewer
Old Feb 1, 2003 | 09:05 PM
Happy CL-S Pilot
Cool! Post an SAE correct Dyno Plot.
Old Feb 1, 2003 | 09:13 PM
mt6forlife's Avatar
What's the story on the huge torque drop between 3500 and 4000?
Old Feb 1, 2003 | 09:23 PM
Happy CL-S Pilot
No problem at all.. it just the fact the torque scale on the right is overblown from 175 to like 220
Old Feb 1, 2003 | 09:51 PM
kritikadeo's Avatar
Starving CLS Driver
Well the program does not let me cut, copy or save so i cant get the file onto my hard drive in order to post it on the forum. On top of that, i do not know how acurate the program is as far as converting my saved run files to the sae format. So the best thing i can do is call up the dyno shop. have them convert to sae by using my data files that they saved on their hard drive then having them emailing me that new file and then me posting that new graph up here on the forum. Well, maybe if i have time i can do all that. But as far as i am concerned, that was the graph given to me and that is what i have to post. But the funny thing is that the graph says 200.2 torque but if you follow the torque line, its actually around 199.5 ft-lbs at 5900 rpm at its peek. HP line seems consistent with the data. And the graph states 234.8 HP and 200.2 torque. So if you follow the lines it comes out to be 234.8 hp and 199.5 ft-lbs torque. I apologize for the inconvienence.
Old Feb 2, 2003 | 11:00 AM
kritikadeo's Avatar
Starving CLS Driver
Just talked to the dyno shop and they will be emailing me the SAE HP corrected graph sometime tonight so we can see what the figures are from these runs in that format. Stay tuned. So what is the difference from STD HP and SAE HP anyway.
Old Feb 2, 2003 | 11:39 AM
Happy CL-S Pilot
I think that STD is not weather corrected and SAE is... I may be wrong... but 4-5% difference is not out of the question.
urbtsx
Mar 4, 2017 06:53 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
JDMEXI
Sep 10, 2015 10:01 PM
BlueAquarian
Sep 10, 2015 02:18 PM
