Anyone done a gas shock trunk conversion?
Old Dec 7, 2005 | 04:57 PM
stillwaterd's Avatar
The Kicker Guy
I've seen it done on the TSX, but not a CL. Has anyone succesfully pulled it off? I need a little more room under the package tray for my system, and the torsion springs are just getting in my way.
Old Dec 7, 2005 | 07:14 PM
morgan040's Avatar
that sounds like a good idea...... My torsion bars broke at the cheap welds where it mouts to the top rear deck. I could use some shocks back there. My stupid trunk won't stay open. Dynamat is way to heavy!!!!!
Old Dec 7, 2005 | 07:56 PM
The Kicker Guy
Yeah, I just noticed mine did to. I don't know why they put those damn torsion bars in there. I really wanted to vent my cabinet through the factory rear speaker cut out in the package tray, but these bars are getting my way.
Old Dec 7, 2005 | 08:42 PM
CleanCL's Avatar
same shit happened to me, had to make my own bracket
Old Dec 7, 2005 | 09:49 PM
Lord Helmet's Avatar
I'm here in spirit...
Mine broke too but it was under warranty. I took it in and they had a body shop fix it. It only took two or three times back and forth to Acura's shitty service dept. for them to get it right.
Old Dec 7, 2005 | 09:59 PM
The Kicker Guy
Mines still under warranty as well, but with the cheap ass little tack welds they use, I can't imagine it would take very much pressure for it to break again.
Old Dec 7, 2005 | 11:45 PM
CleanCL's Avatar
yup, i drilled out the holes in the bracket and threw in some self tapping screws with lock washers to hold it in place, that bad boy is in there good now.
but back on topic, it would be interesting to do gas shocks, i would like that and could foresee removing all those tension bars for some loss of weight in the trunk and increase space.
Old Dec 11, 2005 | 02:24 PM
The Kicker Guy
I'm going to be attempting this sometime in the next couple weeks. I post pics as I make more progress.
Old Jul 23, 2008 | 09:29 PM
loweredCL's Avatar
Hello guys,
I just saw this thread and wanted to know if anyone has actually changed from torsion bars to struts??
Old Jul 24, 2008 | 07:40 AM
fuzzy02CLS's Avatar
Not that I have seen. The problem is in the design of the trunk opening. There isn't room to add them around the opening with the truck still closing. You would have to fab some brackets that bolt under the rear deck then a bracket that mounts to the trunk lid. Then mount the gas shocks to these brackets.
It really shouldn't be hard to do if you can make a bracket.
Old Aug 5, 2009 | 02:52 PM
douggiestyle's Avatar
I'm bumping this in hopes that someone's done this for our cars. There's a great DIY on the TSX side here https://acurazine.com/forums/1g-tsx-2004-2008-124/gas-springs-replacement-tsx-trunk-write-up-finally-finished-310278/Sola
Seems like it would be the same for our cars but every trunk is different.
Topher's CL
Solaris' TSX
He used 2x80lb rated shocks. Our CL trunks w/o spoiler is 25 lbs, not sure if this is going to be overkill. Anyone know the weightof 1G TSX trunks?
Old Aug 5, 2009 | 05:27 PM
fsttyms1's Avatar
I did it years ago to my TL. Nothing quite as neat as that but i used 1 to help with the wing (i was sick of the trunk slamming shut on my head)
Old Aug 5, 2009 | 06:00 PM
thanks! time to put in an order
Old Aug 5, 2009 | 08:35 PM
aznboi2424's Avatar
if someone has done this, can you make a DIY please. My trunk is fail right now ever since the bracket came off the welds.
Old Aug 8, 2009 | 05:49 PM
loweredCL's Avatar
Thumbs up
I've tried many times to do this on my CLS, but the problem is not as much the mounting, but the arms that lift the trunk lid. They are very weak and when I put pressure on them with a strut, when the lid shut, the side with the shock would sit up by the window. I am still looking for a solution, different size struts, load and strokes, and mounting points, but still not there. I took my torsion bars off so I could put better speakers on the back deck.
Old Aug 10, 2009 | 12:51 AM
dave586270's Avatar
Chamorro
I've never heard of this. My trunk still works perfectly. Had to zip tie the plastic 'bridge' piece that holds the bars together but thats it. Still stays open and closes perfectly balanced. odd...
xsilverhawkx
Oct 5, 2015 11:00 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
San Yasin
Sep 29, 2015 10:52 AM
jmaxima03
Sep 27, 2015 10:22 AM
