any way to turn off VSA permanently?
Undeer the hood, on the passenger side, you'll see a silver box with brake lines going to it. This is the VSA Module. Try pulling the wire harness from it, then see what happens.
Thanks again for the help.
Originally posted by dhlesq
Call me crazy, but I don't know if I would cut brake lines and then test it by driving my kids to school in the twisties.
Post it
Wire a latch or a buffer to the switch and connect it's power to a 5V supply that doesn't turn off when the car turns off. Wire the latch between the switch on/off button and it will save the state of the button when the car is off.
You can pick up discrete latches or 4 pin latch PLC packages from Radio Shack.
I have used this method to save states of buttons previously, but you may want to remove the switch and apply an external power source and make sure it works before you replace it.
mada51589
05-03-2022 08:54 PM
SidhuSaaB
05-30-2020 12:40 AM
09-17-2015 09:01 PM
