Any step-by-step instructions to swap in Legend Calipers?
Old Oct 2, 2009 | 02:01 PM
01RedCLS's Avatar
Question Any step-by-step instructions to swap in Legend Calipers?
I'm looking for step-by-step instructions (with pictures) to swap in Legend Calipers on a 2001 CL-S.
Thanks,
Old Oct 2, 2009 | 02:31 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Did u ever change rotors and pads b4 and bleed brakes?
If you know how to change rotors and pads the calipers are easy..
Just make sure its not leaking and make sure you bleed it properly.
Old Oct 2, 2009 | 03:13 PM
01RedCLS's Avatar
Fair point. I spoke to my mechanic friend and he wants to know if you need a scan tool to activate the pump, given that it is an ABS system?
He said some ABS systems require this... can anyone confirm?
Old Oct 2, 2009 | 06:38 PM
StonedCL's Avatar
B A N N E D
NO it was pretty much plug and play.. just put the calipers on and thats it..
Old Oct 2, 2009 | 07:37 PM
Rajca's Avatar
wham bam thank you ma'am
the right legend caliper goes on the left side on the car and so goes for the left caliper on the right side of the car. that so the bleeder screw is on top. use the tl/cl oem brackets. no scan tool needed. a few basic hand tools and about 30min-1hr to swap them. make sure u have brake fluid by ur side to fill up the reservoir when u bleed them
Old Oct 5, 2009 | 02:02 AM
dave586270's Avatar
Chamorro
Exactly. Pretty straight forward. GL with install your gonna love those bad boys!
Old Oct 5, 2009 | 07:46 AM
01RedCLS's Avatar
Perfect, thanks guys!
Old Oct 5, 2009 | 11:42 AM
AcuraGman's Avatar
What Year Legend Calipers are you using? Is this a real good improvement over the stock Cals? What are the bennys?
Old Oct 5, 2009 | 08:43 PM
dave586270's Avatar
Chamorro
They should be the dual piston calipers from the 95 Legend LS. There are a lot of threads on the benefits of the upgrade. Mostly stopping force and power. Longer life of the rotors with the power being spread more evenly over the rotor. Great bang for the buck, I speak from experience!
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
thegipper
Sep 28, 2015 01:01 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
