Another try at the dragstrip
Old Jun 8, 2006 | 12:24 PM
Seattle Cl-S's Avatar
Blown LS6!!
As some of you may remember I haven't had much luck at getting any good runs at the dragstrip. 3 trips to the track and only 1 run each time b/f it was too crowded or it rained.
Well, last night was looking pretty nice so after work I went to give it one more try. Some dark clouds were looming in the distance but here in Seattle that doesn't mean it'll rain.
Got to the track and got into line. Not too many cars there so I was pretty hopeful to get at least few runs in. As I got in the right lane what do you think lined up beside me? Yes! An E39 M5 with a really cocky guy driving it. His every other word started with an 'F'. Anyway, about a 1/2 hour of waiting in line and I finally get my first run in (did I mention against the M5?)
Light went green and we took off!
CTSV : M5
60' 2.121 : 2.562
1/4 12.871 : 14.535
MPH 115.70 : 104.46
I must have put no less than 10-12 bus lengths on him. When we lined back up again he came over to me and the first thing out of his mouth wasn't 'Hey, nice run' it was just excuse after excuse. Traction control, bogged it, yada yada yada. It happens to all of us but it was just funny.
I ended up racing 3 more times - once against a 13.8 @ 101 Evo, once against a 14.6 @ 96 E36 M3 and once more against the M5. He did better that time.
CTSV : M5
2.168 : 2.228
12.850 : 13.674
116.11 : 105.40
The 116mph was my highest trap. There was a Viper there too that was only trapping 116mph. Not sure of the year or model but it looked very nice. I thought it should be trapping higher. He came with the M5 guy though so maybe he couldn't drive either. They ended up being ok guys in the end but they just had something to prove in the beginning. Baby-V humbled them a bit!
Old Jun 8, 2006 | 01:32 PM
Time For Sleeep's Avatar
That's Racist
Sounds like you had a great time.
It also sounds like a decent collection of cars.
Nice runs and great story. I it when cocky motherf*ckers get swatted down.
Old Jun 8, 2006 | 02:50 PM
2003TL-S's Avatar
Any chance of you getting a high boost pulley on you car and going for low 12's??
Old Jun 8, 2006 | 06:07 PM
Blown LS6!!
There is one smaller pulley that I've had my eye on... :0 Bumps boost from about 5psi to about 7psi. Most guys running it dyno 480+ with the new pulley. Detonation is always a concern though and cooling the intake charge with a methanol injection or equivalent is recommended to be safe.
With DR's, a guy on the Caddy forum has run 12.0xx@118. Not bad.
Old Jun 8, 2006 | 08:28 PM
ChucksCL-S's Avatar
Great story!
Old Jun 9, 2006 | 01:21 PM
Mike's Avatar
nice runs!
Old Jun 9, 2006 | 02:49 PM
CL Platano's Avatar
Tristate ViP Crew
Nice runs ... sounds like you are enjoying the Caddy
Old Jun 9, 2006 | 04:32 PM
cmark's Avatar
nice work.
Old Jun 12, 2006 | 01:57 PM
02AV6's Avatar
563hp daily
. Get DR, heat them up and you'll run low 12s with that trap and decent RWD traction.
And I'm running 12s too
Old Jun 13, 2006 | 04:07 PM
Blown LS6!!
DR's on this car with result in a blown rear differential
Old Jun 13, 2006 | 10:34 PM
Joe5.0's Avatar
TQ > MPG
Its too bad you cant use all of the power. Hell, my stock H/C/I 5.0 mustang with a Vortech on it should run mid 12's without too much effort. You'd think a blown LS6 would be at least low 12's even if you have to baby it out of the hole.
Oh well, i'm sure its pretty fast from a roll. 116mph is pretty nice.
Old Jun 14, 2006 | 12:56 PM
Blown LS6!!
The best time I've seen with my setup is 12.0 @ 118mph...so it is possible. The guy had DR's and got a 1.7 60' time. He's also a better driver than me...for now. His rear started leaking fluid after a few trips to the track (I know that sounds gross).
A Vortech'd Mustang is a drag-monster. Solid rears definitely help them get moving!
Old Jun 14, 2006 | 01:21 PM
mrsteve's Avatar
His car probably weighs 1,000 pounds more than your Mustang.
Old Jun 14, 2006 | 01:48 PM
Joe5.0's Avatar
TQ > MPG
Actually steve, only about 500lbs more (3300 vs. 3800). Cast iron block & heads really dont help my piggy.
But yeah, GM is known for weak rear ends. Its too bad they have so much axle hop, thats why I dont like IRS.
My dad's 03 Cobra couldnt launch hard to save its life without hopping, and thats hell on the halfshafts.
BTW whats the CR on the LS6? Must be pretty high to only run 5.5psi.
Old Jun 14, 2006 | 03:28 PM
mrsteve's Avatar
Ahh.. I was thinking notch-back not the hatch
Old Jun 14, 2006 | 05:20 PM
Blown LS6!!
I can't remember off hand the CR. I think it's 11.x : 1 or so. The IRS does give alot of wheel hop. Not good for drag racing. However, I also take this car to the road course. That's where the IRS works miracles in such a heavy car like the CTS-V. There's nothing like keeping up with 911's in the twisties and then walking them down in the straights in a frickin' Caddy!
Old Jun 14, 2006 | 07:07 PM
Joe5.0's Avatar
TQ > MPG
Well mines a 94 anyways, so technically its a coupe.
But yeah, IRS in tight corners is nice. More predictable power application that solid axle. I have road-raced mine, and its sometimes a crapshoot whether it spins the inside tire or not.
Old Jun 14, 2006 | 11:36 PM
Allout's Avatar
Blown is Best
I want vids of this. Not because I don't believe you but for entertainment
Old Jun 15, 2006 | 01:28 AM
Blown LS6!!
I'm trying to get back onto the track on June 27th. We'll see about vids then
Old Jun 15, 2006 | 09:59 AM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
nice track times.
Jeff122886
New England
14
Aug 5, 2012 07:54 PM
SuperTrooper169
Southwest
Feb 17, 2012 11:54 AM
johntypes
Sep 19, 2003 02:49 PM
johntypes
Sep 18, 2003 05:58 PM
