Another Interesting mod: Disabling the PCV!
Old 03-14-2003 | 08:08 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
How about disabling the Postive Crank Ventilation hose?
Instead of recycling the air how about Atomspheric release via a K&N filter?
Old 03-14-2003 | 08:31 PM
Happy CL-S Pilot
Maybe we can do the same for EGR, but I am sure we will trip a DTC code.
Old 03-15-2003 | 10:21 AM
Wires's Avatar
Re: Another Interesting mod: Disabling the PCV!
It's the way it's done in the old days when you replaced the air cleaner with an open air one.
It'll give you 0 HP, and just puke a bunch of shitty oil fumes into the atmosphere.
The PVC is run by manifold vacuum, and is only used during idle and cruise. At WOT, you have no vacuum, so you gain nothing.
Same with the EGR valve. At high vacuum it re-circulates exhaust into the intake to lower combustion temperature, which lowers emissions output.
Old 03-15-2003 | 10:49 AM
t-rd's Avatar
haha.. this is been discussed extensively in the past on the Accord V6 forum. The PCV helps pressurize the crank case and prevents blow-bys. Disabling it actually has detrimental effect on the engine over a long period of time.
Old 03-15-2003 | 11:08 AM
johntypes's Avatar
i have pluged the holes on the intake gasket, it does make the car fell better, i will let you no sunday night, after i get home from the track the VSA light comes on after the car is running about for ten minutes.
CL-S progression 01
01-26-2016 04:15 PM
joflewbyu2
10-08-2015 11:16 AM
ROWDY621
09-30-2015 03:20 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
MonkeyTrucker
Southeast
09-25-2015 02:48 PM
Quick Reply: Another Interesting mod: Disabling the PCV!
