alphawerks install is not going good...
I need FI
brought my car in and they are installing the headers as we speak. they said the o2 sensor hit the oil pan (like a lot of people had experience).. what should I tell the dealer to do (since they are idiots...
Please help asap!
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Please help asap!
I need FI
okay. dealer just called. they said the o2 sensor wasnt touching the oil pan, but it was at like 1mm of distance from it so what they are going to do, instead of relocating the sensor, they will grind the oil pan a little bit to leave like 3/4 of a cm so the sensor doesnt touch nor brakes... what do you think? cheesy?
Ich bin auf der autobahn!
Berny ,
That sounds a bit dangerous to me ,rather than toy around with an expensive oil pan let sleeping dogs lie .if the O2 sensor clears the pan you are good to go , that section of the header does not move unless you crash the car so there is no real reason to fool with it .
Jens
Jens
Former Sponsor
The headers do not move. The exhaust sways a little but the headers really do not move. Unfortunately the distance is not much but you shouldn't have a problem. This is why Alpha Werks moved the bung farther back on the latest batch of headers so there would be absolutely no issue with the 02 sensor fitment.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
