Almost money shifted my 2003 CL-S
7th Gear
I was driving today, this being a first real spring day here, so I wanted to have a bit of fun and I mistakenly shifted from 6th to 2nd instead of 4th (yeah, one should let the stick center first then push it down, do not force it to the left). That was around 120 km/h.
So, I release the clutch and watch my RPMs quickly getting to 8000 at which point I press it again and disengage the shifter.
Car seems to drive ok, and I believe it reached 8000rpm only for a split second. Do you think there will be any consequences?
Aside of that, I have yet to redline this car (when I "race", I never brought it above 6000 RPMs), and I wonder what will happen? Will it just cut the fuel off like my beamer did or what?
10 years of driving manual cars. I am ashamed.
Unregistered user
it's okay, i'm really paranoid about shifting to 6th since i rarely go in it... i'm skared of hitting reverse!
but i have "accidentally" shifted from 4th to 2nd, but i always catch myself b/c i slowly let go to see if i'm on the correct gear. (when i was just learning stick).
^useless info to your case, sry
7th Gear
Hmm. AFAIK reverse is physically blocked once you start rolling, so no worries here. Use 6th otherwise it's a gaz gizzler on a highway
Misshift by itself is not a problem. Misshift with RPMs above red line (which is around 7000k for CLS) is a problem.
So I am just trying to figure out what would happen on that particular car have it stayed longer on 8000RPM?
Also, what happens when you just redline it in gear (without misshifting)? I am sure many people have done this.
2014 TL SH-AWD Advance
I now drive an accord....
You are correct, there is no way possible to hit reverse once you are rolling forward You sure better be using that 6th gear with the current gas prices
To the OP if you miss downshift and overrev you could bend valves and other things, basiclly destroying your engine. If you are still running fine at this point, likely there is no damage done.
If you go into redline while normally in gear the car will either kill the fuel or ignition. I forget which at this point, but either way it will feel like you hit a wall and you probably hear a "pop pop pop"
Also you really should take your car above 6K every once in a while, after all V-Tec doesn't even switch over till 5800. So you know it was meant to be taken much higher than that
Originally Posted by GreenMonster
Yes your right Its too early for me, where did my hour of sleep go haha
Originally Posted by jproy
Its not mechanical?
Originally Posted by fsttyms1
Well there is a way. If the reverse lock out solenoid were to go bad you could
MP90 uninstalled
I always assumed it was some how mechanicaly operated when you started to roll forward. I never imagined the ECU and a solinoid were in involved. Thanks for the info. I once put an auto mazda in reverse at 80 mph on the freeway by accident and nothing happend.
7th Gear
You guys are helpful I am not worried anymore. I'll try to scan the ECU with my OBD scanner and see what it shows.
You got a nice community here. I should post more often But then again, I only had car for a couple of months during winter, so real driving hasn't started yet
Almost money shifted my 2003 cl-s
Check engine codes for miss-fire, if you have any but no check engine light you should be OK. Take it from experience dont tread in that redline area and miss a shift cause it will cost you around $3300. to fix. By the way any body looking for a firewall side head real cheap with a bent valve stem let me know. Been driving and racing standard shift for a few years and dont really know when it happend. By the way I was 2 months out of warranty( 25k miles) when it happend and Acura client service wouldnt even help with the parts.
Doing a search for reverse lockout here will turn up one of your pre-conversion info gathering threads from Sept 04 when scalbert was still around
(guess i proved scalbert wrong too... no bs)
7th Gear
Originally Posted by Joe5.0
For what it's worth, it seems 9000 RPM on the tachometer is probably the number engine can take for a very short periods of time (<1 sec) without serious damage.
And, 6th->4th shift gone wrong (actually engaging 2nd instead of 4th) seems to be the most common mistake. I am with the lemmings
And I am still the manual guy. Will never drive an auto again (I drove it for 1 year out of my 10 years of driving).
I had an e46 BMW, and I never actually shifted wrong there, because the shifter is pretty long-throw and forgiving. But I always wanted a short shifter there. Which makes me wonder if short shifter makes any sense for 2003 CL-S - it is already as short as it can be. Any comments here?
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
Hines57
09-24-2015 01:58 PM
