alarm system add on
MR O'NEAL
alarm system add on
alright, i want 2 things to add on to my alarm
a shock sensor... and a 2-way pager,
i know i can add in the shock sensor myself...
but is there anyway to add in a 2-way pager??
or do i just have to install a whole new system??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871815571
that looks like a good deal and is cheap as shit ( less $$ to save $$ = ++++++)
umm a couple questions more later..
MR O'NEAL
MR O'NEAL
hmmm
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871540245
i like that
i think i'm talking to myself
i like that
Retired. Not available.
I dont think or heard of anyone adding paging system to the stock alarm. I cannot locate in the HELM any output or panic output from stock alarm that you could use with those system. The only way to upgrade is adding shock sensor.
To add 2 way paging, do what I did. Add the whole system and make it works with your stock.
1 Post
I added the shock sensor and got a 2 way pager system which has sensors for the doors, hood, trunk, and shock sensor. It worked, except that the shock sensor I bought did not work with the system, and I haven't had time to play with it because I travel too much (this was last year I did this).
But I think the place I bought it form sells the shock sensor that goes with the system which should work with it.
And the system works like the shock sensor, negative triggers, so the only hassle is finding which which wire to wire each sensor too, oryou can just wire it to the shock sensor.
but you ahve to wire it to the ignition too so the system turns off when the car is on.
joflewbyu2
10-08-2015 11:16 AM
09-17-2015 09:01 PM
