Airbag Compatibility For 01 CL?
Old Aug 18, 2008 | 06:56 AM
CL_NOOB's Avatar
2001 3.2CL
Question Airbag Compatibility For 01 CL?
Hi, does anyone know what's compatible with a 01 CL? I did some searching on eBay and Autotrader to see what would fit, it looks like the 02 CL and the 99-01 TL airbags are 100% identical with the 01 CL, so it should be plug and play, right? The 03 CL and the 02-03 TL looks like it would fit just fine, the outer shape of the driver's side looks the same to me, just the inner design is different, I spent a lot of time examining the photos and I couldn't find a difference on the outline. If I am right about the shape, would it be plug and play as well? Or does it have a different wiring harness?
Any help would be appreciated, thanks!
Old Aug 18, 2008 | 07:36 AM
fuzzy02CLS's Avatar
03's are dual stage, You can't use them. Your 01 is a single stage.
Old Aug 18, 2008 | 04:27 PM
CL_NOOB's Avatar
2001 3.2CL
What about modding it? I know someone who's an expert at circuitry, is it do-able? And what about the wiring harness, is it different?
Thanks for your help.
Old Aug 18, 2008 | 05:04 PM
YeuEmMaiMai's Avatar
the 02's are split......single stage driver side and dual stage passenger side
Old Aug 18, 2008 | 08:14 PM
CL_NOOB's Avatar
2001 3.2CL
So what can I use for the 01 CL? Please help me by putting a "Y" on the following models that would work, thanks in advance!
Driver only:
01 CL
02 CL
03 CL
99 TL
00 TL
01 TL
02 TL
03 TL
Passenger only:
01 CL
02 CL
03 CL
99 TL
00 TL
01 TL
02 TL
03 TL
Old Aug 19, 2008 | 12:13 AM
m733l's Avatar
if you know and trust the expert then it is def. doable. i hardwired a single stage s2000 bag to my dual stage 03 cl-s. you will need to take resistance reading and put the proper resistor in place.
Old Aug 28, 2008 | 05:19 AM
CL_NOOB's Avatar
2001 3.2CL
What does stage 1 do and what does stage 2 do?Does stage 1 of a dual stage airbag equal that of a single stage airbag?
Old Aug 28, 2008 | 08:42 AM
fuzzy02CLS's Avatar
Why don't you just get the airbag from an 01 CLS? I've seen sets on Ebay recently.
Single stage means the airbag will only go off in a set impact setting.
Dual stage means the airbag has 2 settings to deploy. A low speed crash & a high speed crash.
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
