After lowering my CL-S
I called Acura of Boardman today to get a quote on installation of Comptech Springs, Tokico Blue shocks, and an alignment and the service department manager warned me that I will probably hear more squeaking in my suspension after I lower my CL-S. He said that normally when a car is lowered, the driver will typically get more noises from the suspension.
To all you guys who have lowered your Cl's, have you noticed THAT much more noise from your shocks and springs??? Just wondering! I thought I had my mind made up to lower my car, but just checking on some last-minute issues. Thanks. And, oh, BTW, installation price will be $670 including the alignment. Plus the cost of springs and shocks takes me to $1,250. OUCH!!! The dealership also said that I should buy the camber kit just in case, and if it isn't needed, I could return it. Is there a camber piece for all four corners, or just the rear?
That quite expensive for just lowering my car. But, I want the work warrantied, so I guess I should expect to pay more.
Poppin them thangs
Re: After lowering my CL-S
1250 for install??????? figure 250 for springs...thats $1000 for install alone....i paid $100 cdn installed....that is wayyyyy too much...if ur adamant about acura installing, call another dealer!
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
FYI, even if you get the work done at the dealer, it's not going to be warrantied most likely. I'd find a shop to do it for A LOT cheaper!
Poppin them thangs
also, you will feel/hear the road more when lowered, but its a good feeling......
btw, alignment shouldnt be done the same day you install springs....ur car will settle a bit, wait 2-3 wks after to get alignment...dont let acura say anything different....
good luck
good luck
Audi S4 driver
I dont know about that g-unit .. Jens at park ave acura did my spring install (for 250 BTW - 670 is WAY too much) and he recommended doing the alignment at the same time. hes done dozens and dozens of alignments and spring installs .. and my car has been back there since and alignment is fine.
Poppin them thangs
im just going by what ive heard....the springs will settle...
No, that's $1250 for parts AND labor!!! Parts are approximately $580 (That's Comptech springs and Tokico Blues) and labor is $670. Not $1250 for just the labor.
Is $670 for labor and alignment too much???
WAYYYYYY TO MUCHH
a local speed shop should do the install for like 150 MAX!!!
then find a place to do alignment for around 70$.
Out here it's not uncommon to find shops to do install for $50. But the competition is a lot more fierce out here.
Yes, $670 is too much.
As for an alignment, some will say wait and others will say to do it the same day. I did my own installation so I had to wait. However, the car was in spec even with the springs.
Poppin them thangs
if ur comfortable paying that much for peace of mind, then do it...who are we to tell you what to do with your money...im just sayin i wouldnt pay that cuz im cheap !
good luck
good luck
Originally posted by CLpower
WAYYYYYY TO MUCHH
WAYYYYYY TO MUCHH
That's why I posted the question in the first place! Thanks for your honesty. However, I think I want my dealership to do the work; so do I call another dealership and get a quote from them, or just call my guy back and say that I've heard that other dealerships do the install for less??
I don't want to get screwed on price, but I also don't want to screw up the relationship that I have with the dealership......They treat me pretty well.
I wouldnt do that if i were u that is way too much. I got konis, springs, and camber front and rear installed for under 200. Id shop around and find a shop who can do it for a lot less.
Adventurist.
Wow, what a rip. That's seriously too much!
Do it yourself, I did a write-up a week ago, search under my name. Save your $1K. Alignment should not cost more that $65.
My friend and I did my suspension in 2 hours.
Dragging knees in
If a shop has done TL's and CL's many times in the past, they will know what to expect and do. You will get a good price.
If a shop knows about it, or only has done it a few times, then you will get an expensive quote.
If a shop has never done one, you will get a pretty decent quote.
My advice? Call at least 5 shops.
Around here, 150 is near impossible to find. 200-250 is more like it, and some shops will charge up the ass, in the 350-dollar range. Just make sure you shop around. If they try to tell you they will have to charge more because they are also installing shocks, tell 'em to stick it. It's the same thing, whether you're just doing springs, or springs and shocks.
I paid 360 total for comptech springs and installation. I also went to the dealer first to get a quote and it was ridiculous....
as far as noise is concerned, there is more road noise when u go on the highway, but there is no squeeking sound.
$150 is cheap...for removal of the back seat and everything??? I've got to figure at least 1 hour just to carefully remove and install the back seat into place. At least at the dealership, I can expect them to know what they're doing. For $150-200, I really don't want some 18YO kid ripping out my seat, tossing on the springs and shocks, and then giving it back to me a couple hours later. Then afterwards, I hear all kinds of squeaks and rattles in my suspension. But, at the same time, I don't want to get screwed by my Acura dealership either.
How is this gonna screw up your relationship w/ the dealer if you go somewhere else.
But as others will say, if you want to throw away a few hundred bucks and have the dealer do it then go for it. But to let you know, if you have problems w/ it most dealers aren't gonna help you out much.
DC Cruiser
I had my Comptech Springs installed by Tischer Acura in Laurel, $1250 sounds like alot of money!!
Labor + CT Springs = $498
I took my car to Firestone and purchased a lifetime, unlimited alignment package for $150.
Tischer also said they will warrant my stock shocks for 100k, since I purchased the car through them, and have the extended warranty. I had 30,000 miled on my car when I had the CT springs installed.
Adventurist.
Originally posted by 2k1CLS
don't buy a camber kit, you don't need that shit. And they'll probably charge you 500 to install that!!!
The Comptech springs definitely did make some noises and required more frequent lubing than stock. What REALLY changed things was Comptech swaybars and a set of coilovers... everything starts making funny noises then =p
When taking a slope (like a driveway or whatever) at an angle, the sunroof area would make funky cracking sounds. Never had any problems but things definitely made stress sounds.
fap fap fap
dont let them do alignment. just take ur car to les schwab or someplace afterward and get lifetime alignment. its better to get an alignment every 6 months
Silver Bullet
Relationship with dealership?! Like they go home at night and think about how good of a customer you are. THere RIPPING you off!! igt mine done by my mechanic for 100 bucks.
My advice:
I had a TL-S and purchased some CT springs .. lowered my ride.. and HATED IT!!!! you can search my previous thread from several months ago and read all about my frustration w/ the new ride quality:
it was a much harsh ride, MORE INTERIOR ROAD NOISE and suspension noise -- this is very true. The car handled a HELLA lot better, and take offs were INCREDIBLE .. the car just BIT the road and took off .. HOWEVER .. i hated it so much (and the look of it) that i paid the same money ($175) to get it uninstalled and had the stock parts put back on.
So my advice:
Ride in someone's lowered Type S w/ the EXACT type of springs you're looking to buy/install, THEN if you're happy .. buy them and install them at a place other than the dealer. Warranty is crap -- if it's done by a good mechanic, it's all gunna be fine.
You may need a camber kit b/c you may not like the look of the wheels w/ the camber as the car settles with the new springs .. though you technically may not need a camber kit for the drivability of the car.
So my advice:
that's another first
My advice:
My advice:
And your advice about riding in a CL-S with the same setup is wise, but I don't know of anybody local to the 'Burgh with that exact setup. If anybody is in the Pittsburgh area and has Comptech springs AND Tokico Blues, let me know. I would love to go for a ride in your car. I know Smitty has Comptech springs, but I think he has Koni Yellows. But either way, TL_TYPE_S, I will keep your opinions in mind. Thanks.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
