AEM EMS Series 2 for J32, J35, 37!!!!!!
Old 10-16-2011, 01:44 PM
  #41
Lone Wolf
brian6speed's Avatar
People with j swaps are running this. I doubt anyone with a 03 cls 6 speed is running it. It is not compatible with our engine unless you swap the crank sensors to auto ones. It is made for the auto engine mated to the manual trans. You can be the guinee pig.
Old 10-16-2011, 03:07 PM
  #42
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,392 Likes on 4,937 Posts
Along with the sensors you will also need to swap the entire engine harness and wire the gauge cluster and temp sensors to work properly with external signal modifiers.
Old 01-14-2012, 09:21 AM
  #43
03 acura cl type s
rush's Avatar
I was thinking we could probably run a jumper harness ?
Old 01-14-2012, 12:38 PM
  #44
civicdrivr's Avatar
Not when the difference is three wire vs two wire sensors.
Old 02-20-2012, 12:35 AM
  #45
03 CLS-6
1foxbody's Avatar
That's dumb aem would do that, what a tease for the CLS6 guys. I was thinking about selling my aem fic to upgrade so I can have the added features. I know it would be overkill but nothing wrong with that haha.
Old 06-19-2013, 05:05 PM
  #46
03 Boosted CLS
cb717cls's Avatar
did anyone ever get this working?
Old 06-19-2013, 09:39 PM
  #47
Unregistered Member
Karanx7's Avatar
^I'll be running it soon. Super ass easy to use all the automatic wiring, and it's definitely the easiest way to do a 6 speed swap.
The only issue is the tach and engine temp sensor. Still trying to figure that out. Also reverse lights might have to be hooked up to a custom switch.
Old 06-19-2013, 11:51 PM
  #48
J-series addict
yungone501's Avatar
For the crank sensor (possibly the cam sensor as well if it too is not compatible) issue, why not modify/machine the crank trigger wheel and use the auto trans crank sensor?
Old 06-19-2013, 11:55 PM
  #49
Unregistered Member
Karanx7's Avatar
Converting the manual engine to an auto engine is not a big deal at all. Just switch over the parts, no modification or machining necessary.
Old 06-20-2013, 08:16 AM
  #50
J-series addict
yungone501's Avatar
Wasnt sure about part fitment between the two but I figured they were interchangeable. So, whats the complication in that?
Old 06-20-2013, 09:03 AM
  #51
03 Boosted CLS
cb717cls's Avatar
well lemme know if u get it all working right cause i will probably need to get a list from you of exactly what u had to get. Because with my mods i think this is needed to get done.
Old 06-20-2013, 12:57 PM
  #52
Unregistered Member
Karanx7's Avatar
Do you have a 6 speed, or auto?
Old 06-20-2013, 09:56 PM
  #53
civicdrivr's Avatar
Or why not disassemble the EMS box, separate the two boards, and move the jumper to "HALL" and run it off the stock 6MT sensor set and harness (jumper harness at the ECU required)?
http://s23.photobucket.com/user/civi...72324.mp4.html
Old 06-20-2013, 11:15 PM
  #54
J-series addict
yungone501's Avatar
Lmao, this would make things entirely too easy. Everybody, remove your engines, install the full auto setups and then reinstall the engine. If you forget to tighten the crank pulley bolt, repeat the first few steps but this time TIGHTEN the bolt and then reinstall the engine again. It's THAT easy....
.....move a jumper. HA!
Old 06-21-2013, 12:07 AM
  #55
civicdrivr's Avatar
Seriously though, there is a jumper on the board. The EMS will run a CL-S6 sensor set and harness. Need a picture of it?
Old 06-21-2013, 12:14 AM
  #56
Unregistered Member
Karanx7's Avatar
Would that jumper spit out correct tach, speedo, and engine coolant temps?
Old 06-21-2013, 09:04 AM
  #57
03 Boosted CLS
cb717cls's Avatar
6 speed
Old 06-21-2013, 05:14 PM
  #58
Dharma Member
ahxChun's Avatar
sounds simple
please do,
Old 06-22-2013, 11:19 PM
  #59
03 CLS-6
1foxbody's Avatar
Ding ding you hit the nail on the head lol!! That's what I'm doing with mine. Using manual sensors and gears. Also not using a auto harness!
Old 06-22-2013, 11:32 PM
  #60
03 CLS-6
1foxbody's Avatar
Only swapped cars have problems with the tach because it's originally setup for a 4cyl engine, our clusters will work fine since they are designed to work for a V6. Same goes for the speedo because usually swapped cars come with smaller wheels and tires from the factory so the total tire diameters are different which would throw the swapped cars speedo off since it doesn't have the correct speedo gear installed for the tire differences. As far as the coolant temp that can easily be fixed with a sensor swap or in the software in the aem. Just like civicdrivr said aem can be switched between hall or mag sensors. So a harness and sensor swap isn't necessary.
Old 06-23-2013, 03:36 AM
  #61
Unregistered Member
Karanx7's Avatar
^No no, I'm pretty sure the EMS will spit out Tach and Speedo made for a 4 cylinder Cluster. The Accord 4 cyl cluster takes the readings correctly, but not the 6 cyl cluster.
It's cuz the EMS was made for integra and civic swaps. I'll have to look into the EMS MAG and HAL differences.
I'll have to go auto because of the dash wiring. The Auto dash wiring is plug and play for the EMS, whereas the Manual dash needs to be rewired.
If you're already a true 6speed CL then Civic's method probably works best.
Old 06-23-2013, 12:59 PM
  #62
03 CLS-6
1foxbody's Avatar
That's only because it's pre configured to be used in a swapped car. The software settings in aem can easily be changed to be used with a 6 cylinder engine and tach. I don't think anything has to be rewired for a manual dash I haven't heard of that. I'm not even sure what that would have to do with the aem lol? The oem pcm doesn't control anything with the dash..
Old 06-27-2013, 08:34 AM
  #63
Lone Wolf
I have heard that haltech makes something for the j32. Has anyone researched this?
Old 06-27-2013, 01:00 PM
  #64
Unregistered Member
Karanx7's Avatar
Hmm, I haven't read about that on this board. It seems that the S2000 cars running with J32A2 swaps can use it though.
I don't know if it would work properly with our cars, or if it would be easier than the AEM EMS 2.
jmaxima03
09-27-2015 10:22 AM
kingbharj
09-25-2015 07:25 PM
Quick Reply: AEM EMS Series 2 for J32, J35, 37!!!!!!
