AEM CAI rattle
HELLLLLLOOOOOO NURSE!!!!!
AEM CAI rattle
Sup guys, I've got this annoying rattle that I'm sure comes from my CAI rattling off one the bolts in the engine bay. I have a bypass valve, and this bolt sits low in the engine bay, before the bend for the air filter. Has anyone had this problem and how did you fix it? Thanks alot guys. I will try and post pics of what I mean if I can.
1 Post
it might be rattleing agains the endge of teh hole where it goes into the fender well where the silencer used to be. I had to get a tube, and slice it downt eh middle and put it as a guard against that forner so that it wouldnt' rub/rattle on that edge. If it's touching any walls or edges see if it's loose enought to pull away from teh wall thengo back and hit it, that could be it.
on a side note... I don't have a bypass valve on my CAI but I live in a hilly region and there is raerly water deep enough to fully submerge teh filter. How does the bpass valve prevent watter getting sucked up anyways, and don't you lose a couple HP from it?
Blown LS6!!
I did the same thing as Ghost when I had one. Just slice open a piece of a rubber coupling and wrap it around the CAI at the bend nearest the filter (easier if you take the bumper off...)
Blown LS6!!
Originally Posted by Seattle Cl-S
I never would have installed the bypass valve if this forum hadn't scared me into it. I think it's pointless. You literally have to drive through a puddle of water deep enough to submerge the end of the CAI to suck up water. BTW, I live in Seattle...
Total time - 30 min, including troubleshooting... (also checked the lower tube rubber mounting stud for security)
Cheers!
Jim
lanechanger
10-13-2015 10:56 AM
