Adding TL console for rear AC/heat ducts
Old 04-13-2011, 10:24 PM
NDM
NDM's Avatar
Sometime in the middle of summer or winter people (the kids) complain about it is too hot or too cold the rear seats so I have to set the a/c or the heater to full speed and then is my turn to say it is too hot or too cold here.
So one day I was at the dealer and I saw a 2003 TL with the doors opened and I noticed it had two air vents for the rear seat. I started checking part numbers and I found out that the TL front and rear console have the same part number that the CL has, so I ordered the air duct (83410-S0K-A00) and the end of the rear console were the vents are (the part number depends on the color) and here is wha t I did.
First, I remove the negative cable from the battery (set the gear lever to neutral so it will be easier to take the front console off).
I removed the front and rear console.
I removed the radio and the A/C controls (Navi system).
There were wires everywhere and behind all these harnesses there is a cap (label UP) on the back so I just took it off, here is where the air duct is going to be connected. . Remember, you have to be careful making space for the air duct, too many connectors and wires specially the antenna cable if you do not pay attention you will push it back with the air duct and probably you will forget to put it back in the radio when you are assembling everything ( it is not that happened to me ).
There is a bracket that comes attached to the front console; this bracket will be replaced with one that is attached to the air duct.
After I connected the air duct and make sure everything is working I put the rear console back, the rear console has two ducts on each side where the air duct that I just installed slide in.
I almost forget, I changed the back of the rear console for the one that has the air vent, pretty easy 4 screws, by the way; I used the same pocket console (looks like an ashtray) that the rear console had.
In this picture you can see the rear console air ducts.
Here you can see both air ducts, so the front ducts have to slide in to the rear ducts.
I had to reset the SRS light because I turned the switch to on position to check the air output and the seats were off so I think that the reason for the light be on.
I am sorry I did not take too many pictures and also this is not the best write up you have seen either but it give you the idea.
Old 04-13-2011, 11:25 PM
I'm Cool
Bobbydoedoe's Avatar
whoa, good find. please do post pic. interested in doing the same mod
Old 04-14-2011, 08:04 AM
Lone Wolf
brian6speed's Avatar
This has been done before by a few people, noone did a write-up with pictures tho. Good job.
Old 04-14-2011, 08:27 AM
fuzzy02CLS's Avatar
That is cool!.
Old 04-14-2011, 11:51 AM
StreetKA's Avatar
This is cool but basicly not to many people use their backseat at all in a CL. Good job !
Old 04-14-2011, 11:57 AM
p.diddy's Avatar
+1 if i actually used my backseats i would probably do this mod.
Old 04-14-2011, 12:18 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
there are already vents going underneath the seats. does this cancel them out or..? because if it does not then it must reduce the flow to the people in the front seats. right?
Old 04-14-2011, 02:56 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,147 Likes on 4,814 Posts
Thanks for the writeup!
Old 04-14-2011, 03:30 PM
aznboi2424's Avatar
Thanks for the write up and pictures! I've always wondered about this mod but I don't use the back seat enough to ever look into it or pay for the pieces. But if I come across a junked TL, I may just pick this up
Old 04-14-2011, 05:04 PM
i noticed the vents under the seats only work on full auto.. I think. would this be the same for the vents ur adding or would they work on more than one setting?
cause I found it odd the under seat vents don't work that well (are not nearly at full power) when u select the floor vents.
Old 04-14-2011, 05:30 PM
aznboi2424's Avatar
they only work when your vents are set to open at the feet. So at full foot or half foot/body.
Old 04-14-2011, 05:45 PM
but on the full auto setting, i'm pretty sure they're on somewhat at least.. (so i've been told by the backseat drivers lol)
Old 04-14-2011, 07:08 PM
civicdrivr's Avatar
Only if the foot vents are on....
Old 04-14-2011, 07:32 PM
NDM
NDM's Avatar
This is correct, in the other hand; the rear console vents work in any position (front, floor, front/floor, and defrost/floor).
Old 04-14-2011, 07:39 PM
NDM
NDM's Avatar
Yes, the front air output is reduced but no very much.
Old 04-14-2011, 07:46 PM
NDM
NDM's Avatar
Hey aznboi2424
Thanks. I think I paid $25 for the air duct and may be around $30 for the rear vents, it will be cheaper in a junkyard as long you do not have to take the console a part.
Old 04-14-2011, 07:53 PM
NDM
NDM's Avatar
I have a quick question, how can I edit my first poster? like if I want to add another picture.
When I posted it, it had the edit botton but now it only has the quote botton.
Old 04-14-2011, 07:59 PM
civicdrivr's Avatar
You can only edit a post within 15 minutes.
Old 04-14-2011, 09:06 PM
NDM
NDM's Avatar
ok, thanks.
Old 04-14-2011, 09:09 PM
civicdrivr's Avatar
What I would do is copy everything you have in the original post, make your edits, post it as a reply in here and if you ask nicely a moderator might make the changes for you.
Old 04-14-2011, 09:11 PM
NDM
NDM's Avatar
Yes, you are right but I am still have a kid that can not seat front because the airbags so he has his backseat already assigned.
Old 04-15-2011, 07:10 AM
fuzzy02CLS's Avatar
NDM
make another post with the added info & I'll move it into the original. Will also be FAQ'ing this thread.
Old 04-15-2011, 08:25 AM
NDM
NDM's Avatar
Originally Posted by fuzzy02CLS
NDM
Thanks.
Old 04-15-2011, 08:36 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Remember, this wont work on the 6 speed. The center console cupholders are different and get in the way.
Old 04-15-2011, 01:48 PM
civicdrivr's Avatar
Its been done before on a 6MT.
Old 04-15-2011, 01:51 PM
ScoobyZINE
AMUA6's Avatar
That's pretty sweet!
Old 04-15-2011, 09:52 PM
aznboi2424's Avatar
NDM, if you need to respond to multiple people, please use the multi-quote button. Its the button next to the quote button.
Thanks.
Old 04-17-2011, 05:32 PM
Jacobpockros's Avatar
Great work man!
Old 04-17-2011, 06:24 PM
NDM
NDM's Avatar
Thanks.
Sorry, I will.
Thanks for let me know.
Old 04-18-2011, 04:51 PM
m733l's Avatar
that's a pretty nice mod. i doubt i will ever do it cuz i dont have ppl back there-ever. Nice find nonetheless!!!
Old 04-19-2011, 03:40 AM
YeuEmMaiMai's Avatar
my car gets cold very quick (tinted windows) so I really have no use for this mod but it is cool nonetheless
Old 04-24-2011, 07:31 PM
o1s
o1s's Avatar
i might try this out. my kids are always bitching in the back about it being too hot.
Old 10-07-2014, 10:43 AM
alexbenz's Avatar
i know the thread's old but the pic don't load...anyone have pics of these mods?
Old 10-08-2014, 08:52 AM
NDM
NDM's Avatar
I do not know what happened with the pictures, I am going to check if I still have them, I will let you know.
Old 12-25-2014, 06:25 PM
01RedCLS's Avatar
I'm interested too! Subscribed..
Old 08-20-2015, 10:47 AM
alexbenz's Avatar
were you able to find the pictures?
Old 08-22-2015, 08:19 AM
NDM
NDM's Avatar
Hi
I am sorry but I could not find those pictures.
It is a time consuming job but it is easy( if you have the patience), I really enjoyed doing it and even better, no more it is too hot or too cold.
02-25-2020 09:57 AM
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 10:16 AM
09-14-2015 10:09 PM
Quick Reply: Adding TL console for rear AC/heat ducts
